mosfet on-off delays vs fs and deadtime - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th October 2012, 01:57 PM   #1
Default mosfet on-off delays vs fs and deadtime
So I decided to try a class-D project. Up till now it's mostly been tube...
I've been trying to estimate on a piece of paper, prior to building and testing, what switching frequency I can use when I know the on-off delays and on-off rise times of a given MOSFET. I would like to switch as high up in frequency as possible, but if I want to use all available voltage from 1% to 99% dutycycle, the fs cannot be so very high. Lets say on-off delays and on-off rise times totals 100ns, which will be the minimum pulse width, so 1%DC = 100ns. (Won't it?) The fs can be no more than 100kHz (10us).
Is it common to use higher fs, and simply let some voltage go unused, say having dutycycle vary from 10-90%?
Also regarding deadtime:
I find it a bit confusing that some say more than 40ns is detrimental (to THD) when most MOSFETs have total on-off times much more than that. The so called 'commutating current' in the LP-filter choke supposedly mixes this up as far as I understand (which is one of many parts of this I don't really understand well enough).
I've done some tests with IRF740 and 730 to measure on-off times, and the 740 need about 80ns to turn completely on and about the same (slightly longer) to turn off. I think the IRF640 is about the same. Yet it seems to me deadtimes of about 40ns is common with the 640.
I'm not trying to suck free info from anybody, just how I can theoretically calculate how high I can go in fs, as well as understanding deadtimes vs datasheet given delays. I have spend many hours reading various app notes, but the above still doesn't stick with my greys. Thx
Old 15th October 2012, 08:24 PM   #2
"'ve done some tests with IRF740 and 730 to measure on-off times, and the 740 need about 80ns to turn completely on and about the same (slightly longer) to turn off. "
->Turn on and turn-off time depends on 2 parameters: MOSfet total gate charge and driver current. Q = I x t.
If the driver can supply enough current, you can turn it on as fast as you desire.
Q is a constant of your MOSfet, if I is increased, t will decrease, and vice versa.
Old 15th October 2012, 09:12 PM   #3
Thnx for reply.
No it will not turn on any faster than specs on datasheet. This is due to impedance between gate driver and MOSFET gate and parasitic capacitance.
I used a +-9A capable gate driver and about 1/4" distance between driver output and gate. (Plus a 5ohm SMD resistor in series with gate). Gate driver was UCC27322 and it was in turn driven by UCC25705 SMPS controller spoofed into running at a frequency and duty cycle according to potentiometer settings.
My tests got results about on par with datasheet claims.
I understand well the reasons for td-on, tr-on, td-off, and tr-off. I just don't quite grasp the theory to calculate the stuff in my first post. I guess I need to get comfy with reactive components a bit more. Something rather complex occurs in the dynamics when top and bottom side MOSFETs do their switching into a reactive load.
Old 15th October 2012, 09:22 PM   #4
"I used a +-9A capable gate driver and about 1/4" distance between driver output and gate. (Plus a 5ohm SMD resistor in series with gate). "
The 5 Ohms will limit the peak current, so that your 9A driver does not deliver full current. Try decreasing the res and see how it gets faster.
BTW: Your MOSfets are not really "up to date"..
Old 15th October 2012, 09:29 PM   #5
Edit: parallel posting...
Just to clearify...I know even with a +-9A driver, I cannot get that out with a 5ohm resistor in there. (Besides...do we really believe this tiny package (driver) can actually source and sink 9A?) But I checked the gate current with a current transformer and the current was less than the potential 2A the driver could have given (10V drive).
Also when I say impedance between driver and gate, even directly coupling driver pin to pin, will still give an impedance that gives the delays.
Edit 2: the drain current and source currents are not same scale due to drain current measured with current transformer while source current using a 0.25ohm resistor.
Old 15th October 2012, 09:38 PM   #6
jcx is online now jcx  United States
depends on gate type and package how well a MOSFET responds to increased drive - metal gate can be turned on/off much faster than poly-Si due to the lower sheet R - assuming parasitic LC doesn't limit 1st - which can be adressed by packaging
http://ixapps.ixys.com/DataSheet/IXZ316N60.pdf has single digit nS ton/off
Old 15th October 2012, 09:38 PM   #7
Agreed....had a bunch on hand. But still, seems folks have been using similarly out of date -640s with very little deadtime - which is what gets my head spinning...
Old 15th October 2012, 09:39 PM   #8
If your gate driver is pulling to 10.5V, gate threshold is about 6.5V, so the difference is 4 V across the 5Ohm resistor -> 0.8A peak. BTW: The driver CAN deliver 9Amps peak.
Old 15th October 2012, 09:42 PM   #9
Interesting MOSFET. Looks pricey switches in < 10ns! But almost 2nF Ciss!!!! Now the 9A gate driver will have to prove it's worth
Old 15th October 2012, 09:43 PM   #10
Actually 'only' 40nC gate charge to 10V. Not that bad.
Problem with IRS2092 Deadtime fanmade Class D 15 26th June 2012 11:51 AM
Best Deadtime Delay Circuit in Class-D Workhorse Class D 28 20th April 2007 03:35 PM
Measuring deadtime Brian Oppegaard Class D 39 21st July 2005 07:23 AM
No more delays, everybody speaks for himself GRollins Everything Else 51 22nd October 2002 09:35 AM
Copyright 1999-2017 diyAudio
