Grounding and shielding in B&O ASP1000 module, help wanted!
Old 8th October 2012, 07:10 PM   #1
Dea944t is offline Dea944t
Default Grounding and shielding in B&O ASP1000 module, help wanted!
Just put together an amp based on the B&O ASP1000 module but I'm slightly confused over the B&O grounding and shielding recommendations.
The module heatsink is screwed directly to the chassis side wall (15mm alu) and bottom (3mm alu).
I will use an SE-input (normal RCA cahssis connector) so VI- will be shorted to AGND on the board.
In the datasheet and designers manual it is stated that the low-level AGND and high-level PGND are shorted and then connected to the heatsink via 10kohm//30nf and that the heatsink is connected to the board power connector earth-pin.
So the signal ground is separated from earth by 10kohm//30nf.
Since I've screwed the heatsink directly to the chassis at multiple points I will have a really low ohmic connection between the modules earth pin and the chassis.
So far so good.... but it is also recommended that the low-level input chassis connector ground should be directly connected to the chassis.
This will mean that earth and signal ground are connected together which seems strange to me.
Any recommendations/comments?
Two more questions:
- I plan to use shielded power cable and plan to use this internally as well. Is it better to use normal twisted cables with a ferrite than the shielded cable?
- I also plan to use shielded loudspeaker cables (shield connected to PGND), so same question as above?
/Dea
Grounding and shielding in B&O ASP1000 module, help wanted!Hide this!Advertise here!
Wanted a UCD 700 Amp Module unit older type domtweaker Swap Meet 0 17th August 2012 03:25 AM
B&O ICE Module Problem - ASP1000 jdubs Class D 3 4th May 2010 07:38 AM
Nice article by Tom Van Doren on grounding, shielding and EMC andy_c Everything Else 3 4th December 2009 03:02 AM
PCM1732U shielding & Grounding KevinLee Digital Source 4 1st February 2008 12:21 PM
plastic cases and grounding - shielding then_dude Solid State 2 13th October 2007 03:15 PM
Copyright ©1999-2017 diyAudio
