diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Stereo to mono (http://www.diyaudio.com/forums/class-d/220930-stereo-mono.html)
nige838 4th October 2012 06:19 AM
Stereo to mono
I'm tyring to tie stereo inputs to mono feeding a TA2020. The best way that I have found is to run both stereo inputs into 10k resistors and then join the resistors and feed it into one side of the amp. I've been told that I should time the input to ground, but I don't understand why.
I'm hoping/asking for some feedback.
THank you for your time,
NiGe
runebivrin 4th October 2012 06:36 AM
The way you're doing it is fine, but 10k might be a little on the high side. It could potentially cause some treble loss. Depending on the signal source anything down to 1k should work.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
