Go Back   Home > Forums > Amplifiers > Class D
Old 30th September 2012, 05:06 PM   #1
Default I2C and analog inputs?
Hi, I'm making a very small and efficient headphone amplifier, but I see that most of the amplifiers of this type are designed for phones, and use the I2C standard for inputs.
My question is: Can I just input an analog signal to drive an I2C input or is it a lot more complicated than that?
Old 30th September 2012, 07:31 PM   #2
I2C is a digital serial data bus and will NOT work with analog signals.
Also I2C is usually used for controlling the internal functions of the amp ic such as volume, tone controls, high/lowpass filters, muting and that kinda stuff, for the actual audio data, the bus use to be called I2S, which is similar to I2C, both having a clock line and a data line.
The point of life is to build atleast one audio amplifier before you die.
AV recievers & analog inputs steverb Solid State 1 6th January 2007 12:24 AM
FET inputs or bipolar inputs on a power amp? ash_dac Solid State 150 17th October 2006 06:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
