any one have TA2022 pcb with protection?
Old 21st September 2012, 09:04 AM   #1
Hadighorbani is offline Hadighorbani  Iran
Default any one have TA2022 pcb with protection?
Hi
i need TA2022 amp pcb with protection
i can not creat good pcb with shematic
thanks friends
Old 24th September 2012, 08:53 AM   #2
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Is this any good?
TA2022 board
Old 24th September 2012, 10:04 PM   #3
Originally Posted by activexp View Post
Is this any good?
TA2022 board
thanks friend but i want creat it by my hands not buy it
Old 11th June 2013, 06:33 AM   #4
mendhi is offline mendhi  India
Default TA2022 problem
Hi my name amit from India i have purchased TA2022 Audio Power amp from Ali-express.com
my circuit version 1.2 in my circuit not applied 100uH coil but add 7810 Regulator ic
(MAIN PROBLEM IN MY CIRCUIT POWER ON THAN LED UP BUT NO RELAY CLICKED NO SPEAKER SOUND I HAVE ALREADY APPLY PRE AMP TO LINE IN I HAVE CONNECT SPEAKER ONE + TERMINAL DIRECT CONNECT RELAY POLE AUDIO IS ON BUT NOT WELL SOUND SPEAKER CONE PAPER GO DOWN SIDE OF SPEAKER MAGNET WHAT IS PROBLEM I HAVE CHECK ALL COMPONENT CONNECT PROPER BUT BTL MODE IT IS WORK OK NOT RELAY ON DIRECT CONNECT 22uH COIL WITHOUT RELAY WHAT IS PROBLEM IN MY TA2022 CKT
Old 12th June 2013, 06:09 AM   #5
routhun is offline routhun  United States
Hi Amit
Check the voltages on TA2022 and compare wit the ones given in the datasheet. Relay is not activating because there might be Dc voltage on the chip outputs.
routhun
any one have TA2022 pcb with protection?Hide this!Advertise here!
K4700 PCB (Speaker Protection) GeorgeP1111 Multi-Way 3 17th December 2014 08:16 PM
Combined DC protection and tweeter protection? CopperTop Solid State 10 13th January 2011 08:52 AM
Quad 405: bypassing speaker protection PCB? rgonzale Solid State 4 7th December 2006 08:00 PM
PCB Protection DieterD Solid State 13 28th August 2002 01:02 PM
Copyright ©1999-2017 diyAudio
