My new 8 channel home Cinema amplifer "sure" 8x100WATT - TK2050AMP - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th September 2012, 10:28 PM   #1
Default My new 8 channel home Cinema amplifer "sure" 8x100WATT - TK2050AMP
Hello,
Just for fun - today I finished my new sure tripath 8 Channel power amplifer.
I own since 2006 a yamaha RX-V2600 receiver.
My plan is to use the RX-V2600 further as pre-amplifer/processer.
My oppo BDP95 blu ray Player sound so amazing in this combintion. As test I connenct the oppo direct to my new tripath 8 ch power amp.
Wow - my 6 Infinity Beta 50s + beta c360 never sounds so "live" & power driven.
My beta subwoofer SW-12 was complety off for the test.
At first I remove the heatsink and adjust the DC-offset. From the factory came my two 4x100 boards with realy horrible values. All eight channels has values around 100mV to 300mV DC.
After I adjust the offset - all 8 channels have values from 2mV to 7mV (after 30 min. warmup).
Then I order a "blank" case for my setup - and do some work out. Drill holes, place feeds - complete the electronic parts......
Regards, Ronald
Old 17th September 2012, 05:16 AM   #2
Really professional looking job RoNNy379ch!
Old 19th September 2012, 04:58 PM   #3
oorva is offline oorva  Israel
hello
looks great
where did you buy the module and case?
what else would i need for a six channel power amp?
Old 19th September 2012, 05:14 PM   #4
Banned
One 4x100w board and one 2x100w board, and a smps of suitable power. Im pretty sure sure electronics have everything you need, the chassis can be had from places like antek on ebay or modusshop or whatever the name was, or if you feel up to it, you could bend up some sheet metal yourself.
Old 21st September 2012, 03:22 PM   #5
Hello,
thank you! Yes it looks not only great - it sounds great too.
No "bass" hole or other issues in the sound spectrum.
I bought two of this new sure units --> 4x100Watt
The look very clean and professional. Only the DC offset was not perfect....up to 300mV.
Ok, I order my case from --> audiophonics
Regards, Ronald :-)
Old 22nd September 2012, 09:36 AM   #6
Your amp looks nice - what PSUs did you use (brand, voltage, power...)?
Old 23rd September 2012, 07:34 AM   #7
Hello ViennaTom,
I bought two meanwell 27V PSU from sure electronics, too.
Type: S-350-27
Regards, Ronald :-)
Old 12th February 2015, 02:42 AM   #8
Per is offline Per
Where do you ajust dc, dont see any trimmers?
Old 13th February 2015, 06:23 PM   #9
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Surface mount trimmers near the heat sink mounting holes...
/U.
DIY projects blog
Old 13th February 2015, 06:58 PM   #10
Per is offline Per
Is it Lively to be the same on other ebay class d-amps?
Sendt fra min Nexus 7 med Tapatalk
Is it possible to repair nakamichi cd pickup "home" laser? whiterabbit Car Audio 78 23rd July 2015 06:12 AM
Adding "home style" I/O to a "Pro" Amp Soldermizer Class D 2 13th March 2012 03:17 AM
The Future of Music at Home - ARTORA's "ARTOAMP 150" from Denmark tiefbassuebertr Solid State 3 19th January 2010 06:48 PM
Problem with Rotel RB-985 MKII 5 channel home cinema amplifier... hoppaz Solid State 2 9th April 2009 08:04 AM
Copyright 1999-2017 diyAudio
