Cheap TPA3118D2 boards, modding them and everything that comes with it - Page 193 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 20th March 2017, 10:58 AM   #1921
irribeo is offline irribeo  Netherlands
Why not use the Fsw TI tells everone will give lowest THD ? Because someone posts 1MHz sounds better ? Like the 36dB gain sounds better ?
Old 20th March 2017, 11:29 AM   #1922
doctormord's Avatar
No, because the Volt+ is running at 1MHz BD, thats why.
Another thing i'm interested in is the increased THD at around 1Vrms.
Setup:
PVCC: 19V
Gain: 20dB
Load: 4R6 resistive
Stock board, only changed inductors.
For this i tested several different inductors:
The influence of inductance is shown here, 10uH vs 15uH. The "bubble" is flattened and shifted to higher levels:
Different geometries/material at the same inductance:
Lower inductance will shift the "bubble" a bit to the lower end:
Surprisingly the small Codaca CSD1013B dual inductor performed really well, even compared to its more expensive competitor from Coilcraft, the GA3416.
Compared with fig.8 of the TPA3118 data sheet (yes it's BTL), the cheap clone is close to EVM performance with the MSS1278-10uH yet. But of course, comparing PBTL with BTL at the different PVCC/Gain settings isn't accurate.
If now we can get rid of the bubble please.
Old 20th March 2017, 12:39 PM   #1923
Being close with pbtl and with mss-inductor also to btl 3251evm with same inductors already is very good. Board is a little small to easily implement a compact, I know you like them, bootstrap snubber/ prefilter snubber
Main ceramics in outputfilter probably cause some distortion, because also TI tells us. And TI doesn't use single ended input testing/measuring.
The high esr inputcaps they use might help grounded negative (in single ended) input too ???
Old 20th March 2017, 12:44 PM   #1924
doctormord's Avatar
Yes, changing fSW is also pita.
I tried better/different ceramics in the output, can't measure any advantage out of it.
At higher levels, inductor saturation dominates while at lower levels inductance and geometrical construction seem to set the rules.
Old 20th March 2017, 01:43 PM   #1925
doctormord's Avatar
Regarding input caps ESR, i put in 1k brake resistors between them and the TPA pins.. nope.
Old 20th March 2017, 11:48 PM   #1926
doctormord's Avatar
Anyone wants to join in?
Mainly 0402 components.
Selectable Gain (20-36dB) 0R-Jumpers
Selectable fSW 400-1200kHz 0R-Jumpers
BTL/PBTL 0R Jumpers
2u2F Softterm input coupling caps (low noise, automotive)
PBTL with parallel inductors (2x2) 0R Jumpers
Diff/SE Inputs
Anti-Pop-Circuit
BS-Snubbers
EMI-Snubbers
AGND island for AFE
AVCC RC-Filter
LC-Filter or Ferrite+C filter or filterless
Master/Slave/Daisychain synchronisation
44x35mm (Length x Wide)
High-Current connectors for PVCC and outputs 2x3 Snap-in
4x M3 (3.2mm) mounting holes
Mute/Shutdown input
opt. LED for power/fault
opt. hickup-mode
No polarity protection
Smaller than Volt+
Old 21st March 2017, 12:00 AM   #1927
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by doctormord View Post
Smaller than Volt+
It is funny to see that opinions have changed. Your design lacks the cap multiplier though.
If you are looking for testers....
It's only audio. Member of the non modular PCB design committee
Old 21st March 2017, 12:54 AM   #1928
Could you provide a link to TI dealing with cap multipliers, please?
Old 21st March 2017, 01:15 AM   #1929
doctormord's Avatar
What/Which opinions have changed?
I have no opinion about the Volt+, i still just wonder how they achieved this THD-levels at 1MHz..
I'm pretty sure it's not the cap multiplier. (Or as others have mentioned, it doesn't help much with noisy SMPS)
Old 21st March 2017, 09:39 AM   #1930
alkasar is offline alkasar  France
agreed. cap multiplier is a mean, not an end.
maybe...
you earlier said this board will be produced by a manufacturer, not soldered by hand. Are you looking for contributors for the prototypes ?
Worth modding cheap speakers hixyhicks Multi-Way 98 20th December 2015 06:52 PM
Dyna Mark III monoblocks. Driver boards and some questions on modding. Glacierjohn Tubes / Valves 19 26th February 2015 08:00 PM
Advice modding cheap speakers phillybob Multi-Way 3 11th January 2015 01:40 PM
Modding a cheap practice amp (aka polishing turds) MereTenacity Instruments and Amps 2 11th March 2013 09:42 PM
Modding cheap 5.1 surround decoder from eBay eplegutt Digital Line Level 0 17th July 2011 10:35 PM
Copyright 1999-2017 diyAudio
