Cheap TPA3118D2 boards, modding them and everything that comes with it
Old 9th February 2018, 03:02 PM   #2291
selwe is offline selwe
Here is how I do it:
Old 9th February 2018, 03:11 PM   #2292
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
The FP series seem to have better specs than FK, particularly for RC (850 vs 600 at 220uF/35V size). The datasheet only has 220uF total here, the largest capacity FP at 8mm would be 220uF.
I would give it all up for just a little bit more...
Old 13th February 2018, 10:28 PM   #2293
My advice to anyone f-ing with these boards is to leave the rail caps alone. After putting down a ton of heat to break the solder joints, pulling half the traces and, generally, creating a big mess, I think this is going to be an abandoned project. Not sure these are any better than my Sanwu TDA7498 and have been pretty much a headache to mod. The inductor mod was not nearly a problem. Not worth the effort in my opinion.
Old 15th February 2018, 12:09 PM   #2294
Nenola is offline Nenola  Finland
Originally Posted by doctormord View Post
I wouldn't go for this "big" 10uF, better is higher resistance and lower value capacitor - in case of component size. (It's also better to have less capacitance when you deside to left the diode out.) I don't know if the "Giancarlo" mod is needing 10uF. o.O
You may go this way:
Diode is not "a must", but nice to have.
But all in all, doable.
I need to implement your antipop-design, but I'm not sure how. I mean I find the corresponding pins from the board, but am I supposed to replace existing components or just add what you have here? I took a closeup about the situation so maybe you guys could help me.
And what about the used components? Is there some specific requirements for the resistor, capacitor and diode? Can i use a basic through hole-resistor and electrolytic capacitor?
Old 17th February 2018, 11:22 PM   #2295
Seems like I'm the only one having problems desoldering the rail caps on this, so this is how I ended up doing it without lifting traces. I used my ChipQuik SMD1 kit, fluxing the solder joint, heating it up with a dab of the CQ solder on each side back and forth and eventually sliding (not lifting side to side) the cap off. I used 350C temp, though a higher temperature might work better, as the iron with chisel tip did spend more time on the joint than I felt comfortable with (maybe 10s), but with patience, each came off without lifting traces. I installed Panasonic FP 330/25V, these were the largest caps with an 8mm in that series. Measured ESR was .07 on these.
Old 18th February 2018, 02:49 PM   #2296
larzman is offline larzman  United States
Default Finally mounted, wired and testing
Got everything mounted and wired. Testing went well, it worked! lol. These are stock Sanwu's, no mods yet as I wanted to be sure all my other hardware is correctly wired first. All good
Couple of observations, amps connected to Klipsch KSF 8.5, 8-Ohm speakers:
- no audio amp noise, noise is only observed when less than a foot from speakers, then only slight
- using a switch, mute pins make the speakers completely silent
- decent bass for tiny amps, powered by 24VDC up to 6A power supply
- mids & highs are crisp and clear (speakers are a big factor)
- iPhone 6+ can push the amps into thermal shutdown in about a minute
- Chromecast Audio can push amps into thermal shutdown in about 30 seconds
- Alexa won't respond if the music is cranked up, unless it's during a quiet passage
Obviously, the enclusure needs top cover installed. That cover mounts the IEC 120VAC input socket (uses same cord/connector as desktop pc), which includes a fused, lighted switch.
Overall, very happy. Time for some mods and wire routing cleanup.
Old 18th February 2018, 09:46 PM   #2297
zek is offline zek
zek's Avatar
You have no volume control?
Old 18th February 2018, 09:59 PM   #2298
Volume control is done by the streaming device, i.e., Alexa or Chromecast via mobile phone, or bluetooth receiver plugged into 3.5mm input jack. The amp is totally hands-free after power-up and the audio (volume and selection) is controlled elsewhere. Why add the complexity and possible noise source of a volume control?
Old 18th February 2018, 09:59 PM   #2299
irribeo is offline irribeo  Netherlands
Thermal shutdown ? With music ?
I can trip protection easily with music but never the thermal, I think that means above 150 degrees Celsius.
Old 19th February 2018, 12:41 AM   #2300
Maybe I'm inaccurate, using wrong term, but the amps both shut down for a few seconds then came back on for a few seconds, then shut down for a longer time, then came back on, I left the volume unchanged through this until after second shutdown. I was playing the song Feel It Still, by Portugal The Man, modern alternative music. from my iPhone 6+.
Cheap TPA3118D2 boards, modding them and everything that comes with itHide this!Advertise here!
Worth modding cheap speakers hixyhicks Multi-Way 98 20th December 2015 06:52 PM
Dyna Mark III monoblocks. Driver boards and some questions on modding. Glacierjohn Tubes / Valves 19 26th February 2015 08:00 PM
Advice modding cheap speakers phillybob Multi-Way 3 11th January 2015 01:40 PM
Modding a cheap practice amp (aka polishing turds) MereTenacity Instruments and Amps 2 11th March 2013 09:42 PM
Modding cheap 5.1 surround decoder from eBay eplegutt Digital Line Level 0 17th July 2011 10:35 PM
