single ended ucd with gain of 1
Old 13th September 2012, 10:54 PM   #1
switchleg is offline switchleg  Canada
Default single ended ucd with gain of 1
I have been doing a bunch simulations. The best thd and dc off results seem to come from running it from a discrete class a input single ended where all the gain is from the class a amp and having a gain of 1 in the class d stage. Schematics being the same as running it from a balance input with a gain of 4.5 in the balanced differential stage and 4 in the class d stage.... anyone ever tried this on a board?
Old 15th September 2012, 02:54 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
sounds interesting - I think the combination of a class A gain stage feeding a class D buffer is a very attractive idea. What does your Class D buffer look like ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th September 2012, 10:13 AM   #3
as you can see the feedback network is very standard other then the input is using a darlington pair. even with a standard input i seem to get best results with it being ran single ended with using the ucd as a buffer only (due to what seems to be less change in modulation frequency)... though im not sure how it will stack up in the real world.
I also have another design that pspice simulations show that will help resolve thermal drift and keep the comparator balanced... still yet to see it online anywhere so i am about a couple hours from throwing the board through the acid to find out
btw i only use irf530n for simulating as its difficult to find models for any decent new FETS.
single ended ucd with gain of 1Hide this!Advertise here!
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 39 1st June 2017 08:18 PM
UcD need help for more gain opor Class D 7 8th January 2010 05:33 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright ©1999-2017 diyAudio
