Go Back   Home > Forums > Amplifiers > Class D
Old 5th September 2012, 04:52 PM   #1
AP2 is offline AP2  Italy
Default Use TPA2001 as nice Triangle Osc. :)
if you have 5v clean, comp. reduce at only 3.
triangle have 2vP with perfect geometry at 500Khz.
this can be an use...maybe better of this chip.
I have develop this pcb and well tested...in old years. but i not use in my amp's.
..continue
Old 5th September 2012, 06:43 PM   #2
Very simple, 90% of pin connected to gnd (this help noise).
I think not need comment.
Maybe..i add rest of components for complete modulator with offset dc control FB.
Ah...This is undocumented use of chips, of course.
Old 5th September 2012, 06:49 PM   #3
Aint it a bit of a waste of a IC that is already a complete class d amp in itself though ?
The point of life is to build atleast one audio amplifier before you die.
Old 5th September 2012, 06:54 PM   #4
I think not, this is 1w low cost chip but in this way solve a good modulator for big and nice sound amp's. you have new idea for good modulator?
Old 7th September 2012, 05:40 PM   #5
before FB2 connection, think not need explanation.
very good is use of magic property of FET, since for some reason, this circuit uses a single voltage.
someone can also replace the TPA2001 with another circuit for generating the triangular. (this signal is very critical to the fidelity and efficiency)
continue..
Old 7th September 2012, 11:40 PM   #6
theAnonymous1's Avatar
If anyone wants them, I have 25pcs 48-BGA TPA2000 and 50pcs 16-TSSOP. Can't imagine I will ever use them for anything. TPA2000 is the 2W version.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
irs2092 osc freq prob philuknow Class D 10 14th April 2011 12:33 PM
Crystal OSC microsim444 Power Supplies 3 21st November 2009 01:22 PM
N.P. Caps for Osc Output stage Zero Cool Everything Else 12 15th June 2008 07:43 PM
shound I get this OSC.? DragonMaster Everything Else 13 7th May 2005 09:14 AM
Copyright ©1999-2013 diyAudio
