my first ever discrete class d aud amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 29th August 2012, 08:31 PM   #11
stewin is offline stewin  Kenya
the voltage i have tried with no issues is +/-56vlts but i am on my way to drive it with +/-80vlts .
irf640 are nice but in my experience they fail when pushed hard at lower impedance e.g 4ohms ,8ohms . but i think i have a lot of desgin to do in order to make this amp work the way i want.
Old 30th August 2012, 03:24 AM   #12
Yes they get hot when driven on 4ohm load....which fets do you think I should use....fast and working gr8 with lower impedance???
Old 30th August 2012, 07:20 AM   #13
try irfb series. class d from ru has used irfb23n15 at+/-60vlts in discreet class d with success
Old 30th August 2012, 08:51 AM   #14
Ok....can any series with xxnxx will do the job or I have to use irfb series only???
Old 1st September 2012, 08:10 PM   #15
irf540n or irfp250n are good with low voltage
Old 3rd September 2012, 12:38 PM   #16
I got my irs2092 board from sure electronics....its sounds gr8.....and i'm suprised by its response....i have tested it on 50 volts 8ohms load....output was heavy....no heating at all...the output fets were not tightened and till they were just a little warm after playing at full load for half an hour
Old 28th November 2012, 09:28 AM   #17
Hi! I like to build it.
Can you give us details of the output rf coil??
thks!!
Old 28th November 2012, 04:29 PM   #18
thks!!
i used106-2 iron powder material with 22uh rating,,.....have u tried class d before?????????/
My NON-discrete SODFA class-D amp SSassen Class D 142 23rd January 2017 01:46 PM
Discrete, Class A Lateral MosFET Headphone amp (not another follower buffer!) mnturner Headphone Systems 35 6th March 2012 08:52 PM
All Discrete Class-A Headphone Amp mnturner Headphone Systems 33 6th June 2011 02:39 PM
Class-D Amp with Discrete Gate Drivers Workhorse Class D 63 17th April 2008 10:05 PM
Noise problems in non discrete class-d amp Baldin Class D 26 18th February 2007 09:00 AM
Copyright 1999-2017 diyAudio
