Is a 1U enclosure too small for 2x UCD180? It gets quite hot!
Old 21st August 2012, 07:04 PM   #1
maxw is offline maxw  United Kingdom
maxw's Avatar
Default Is a 1U enclosure too small for 2x UCD180? It gets quite hot!
I've just built 2x UCD180HGs and a SMPS400 into a smallish 1U enclosure and it gets quite hot. I'm curious to know if people think the chassis and the cooling it provides is not adequate?
When its been on for a few hours the side of the case with the AMP modules attached gets just over too hot to touch. Not like sizzling hot but too hot to touch for say 10 seconds.
Opinions?
Old 21st August 2012, 10:23 PM   #2
StigErik is offline StigErik  Norway
StigErik's Avatar
If you can still touch the sides of the box, its not getting too hot, then its probably no more than 40 degrees celcius, which is ok.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 22nd August 2012, 02:09 AM   #3
zerokelvin99 is offline zerokelvin99  United Kingdom
From our experience with these UcD modules, they need more heatsink that that :-)
Mount one on the other side, should be far better!
Old 22nd August 2012, 02:25 AM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Is it too late to relocate one of the UCD modules to the other side of the chassis?
Brian
Old 22nd August 2012, 02:00 PM   #5
maxw's Avatar
Hmmm, perhaps I'll try that but will have to buy another size piece from hifi2000. Thanks for the opinions!
Old 22nd August 2012, 02:48 PM   #6
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Just drill 4 holes in the other side of the case so the thing looks symmetrical, and use screws with nuts on the inside to fill in the blank holes.
Only time it'll look odd is with the cover off.
Is a 1U enclosure too small for 2x UCD180? It gets quite hot!Hide this!Advertise here!
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby) maxw Class D 48 26th May 2017 07:47 PM
Aluminium Enclosure with 2x Knobs maxw Swap Meet 2 16th November 2010 11:19 AM
WTB: 2x Hypex UCD180 amp modules and 2x SMPS power supplies jdubs Swap Meet 0 22nd April 2010 02:10 AM
PSU 0.1u + 1u capacitors choice Joshua_G Power Supplies 3 10th January 2010 01:53 PM
Enclosure for 2x kef B139 1024 galop Planars & Exotics 3 11th November 2009 04:07 PM
