How much power can a T130-2 core handle?
Old 17th August 2012, 02:20 PM   #1
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Default How much power can a T130-2 core handle?
Can anyone give me a clue on how much power a T130-2 core can handle?
I'm still a noob with this inductance/inductor stuff, so please forgive me if the question is worded incorrectly.
I'm interested in replacing some 10uH and 20uH inductors with gapped ferrite toroids. The data for the size and permeability of the new cores gives me max current ratings of 12.25A (10uH) and 17.32A (20uH). That's assuming I got the math correct (big assumption there).
I just need to know if the gapped cores have substantially less power handling or not compared to the T130-2.
Old 17th August 2012, 02:30 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
It depends directly on frequency. Which one?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 17th August 2012, 02:55 PM   #3
Well, for the sake of argument lets just say 300kHz.
Old 17th August 2012, 03:15 PM   #4
As a first approximation, see this link:
Amidon IRON POWDER TOROIDAL CORE
Knowing current and voltage, you can estimate power, then given frequency, choose a core. Check if it doesn't saturate, and that it can dissipate power lost in the core and wire without exceding temperature rising.
Good luck.
Old 17th August 2012, 03:22 PM   #5
Originally Posted by Osvaldo de Banfield View Post
Good luck.
No kidding.
Haha, thanks though... I'll go chew on this for awhile and see if I can manage to swallow it down.
Old 17th August 2012, 03:36 PM   #6
Aucosticraft is offline Aucosticraft  India
I am still working on the sheet, So need not be error free.
See if this could be of any help to you. I am working using micrometals core in mind.
attached sheet.
There is always a first time....
Old 18th August 2012, 12:36 AM   #7
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
This app note has a bit of info in it about core size and power dissipation: http://www.micrometals.com/appnotes/...s/ipcs4rfp.pdf
Powdered iron cores technically have an air gap that is distributed evenly throughout the entire core. So try not to think of power handling as a function of the size of the air gap.
Brian
Old 18th August 2012, 12:53 AM   #8
Hi Brian, nice to see you're still lurking in the shadows.
Some of the math and general comprehension required here is beyond me. I'm just going to do what I always do and run with what little I understand and hope for the best.
I'm pretty sure the Ferroxcube cores I'm interested in are more than sufficient for my needs anyway.
Old 18th August 2012, 01:13 AM   #9
BWRX's Avatar
When life permits I make my way back here once in a while
Are the ferroxcube cores the same ones used on other fairly high output power class d amps? If so, you should probably be fine.
When in doubt, look at what other amps with similar power ranges are using and use that as a baseline.
Brian
Old 18th August 2012, 12:13 PM   #10
I was tempted to just assume that at first, but they do custom parts so I started thinking maybe some of these OEMs had parts made with lower permeability than the standard gapped cores.
Stacking cores is always an option to if space permits.
How much power can a T130-2 core handle?Hide this!Advertise here!
MRP-T130 canadianeh Car Audio 3 10th April 2011 07:14 PM
Advent 5002 refoam pics and how much power can my tweeter handle? natek83 Multi-Way 5 1st November 2010 07:38 AM
Finding out the power an unknown speaker can handle NIC1138 Multi-Way 28 19th January 2009 01:17 AM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
Copyright ©1999-2017 diyAudio
