TI TPA3100D2, Amazing Class D Amp - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 30th August 2012, 01:22 AM   #31
wushuliu's Avatar
I have no problem w/ bass or treble. The TBI is similar to the eval board in terms of component values as far as I could tell.
Old 30th August 2012, 01:41 AM   #32
kp93300 is offline kp93300  Malaysia
What is the voltage of the power supply input in TBI?
Old 30th August 2012, 01:41 AM   #33
fakeout is offline fakeout  Canada
fakeout's Avatar
This may sound like an ignorant question but is the eval board something you can just hook up to a power supply and the speakers and get it going right away?
I figured maybe it would be cheaper to build a board myself but I'm not done reading on electronics and I think I might try simple "hook ups" to start.
Feeling Good by David Burns
Old 30th August 2012, 01:43 AM   #34
wushuliu's Avatar
Similar to the eval board: 12-24v
Old 30th August 2012, 01:47 AM   #35
wushuliu's Avatar
Yes.
Old 30th August 2012, 03:11 AM   #36
Hi Wushuliu,
what is the power supply you use?
I am surprised at my finding when compared to Trend audio .
regards
kp93300
Old 30th August 2012, 03:30 AM   #37
wushuliu's Avatar
I use a Meanwell 24v SMPS at 25.8v. I have also used batteries and compared with the TBI and although the TBI sounds a little bit better (due to the buffer?) I did not hear any kind of rolloff... Have you played with the gain?
Old 30th August 2012, 03:51 AM   #38
theAnonymous1's Avatar
The value of the inductors is a little too high for my taste; I used 18uH with good results on the boards I built.
Old 30th August 2012, 03:56 AM   #39
I set the gain at 26 db. Tried a buffer and didnot improve bass and treble.
Vocal has a tube type of sound and is good with the eval board..
I notice that the board use 1uf smd ceramic input caps . The Texas chip is smaller than the Tripath chip.
Hope all this will improve with more cap burnt in.
cheers
kp93300
Old 30th August 2012, 04:35 AM   #40
Bob Richards's Avatar
Sounds like something to look at. I'd replace the ceramic input caps with some polypropylene caps. Maybe of slightly larger values too (2.2uF?).
Troubleshooting TI Class D EVM amp? fizzsweden Class D 4 18th July 2011 10:29 PM
Volume control for class D audio TI-600 amp subwerker Class D 2 13th June 2011 10:11 PM
TI class d eval kits Tekko Class D 16 14th August 2010 05:17 PM
FS: Class-D TI TAS5010 & TAS5112F2 Evaluation Board ralphs99 Swap Meet 7 25th March 2009 12:21 AM
Class D amps using TI chips? picklgreen Class D 0 7th January 2007 01:20 PM
Copyright 1999-2017 diyAudio
