TI TPA3100D2, Amazing Class D Amp - Page 18 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th February 2013, 02:29 PM   #171
DUG is offline DUG  Canada
10uH, higher current rating...for higher current
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 17th February 2013, 03:33 AM   #172
kp93300 is offline kp93300  Malaysia
Dug
Very nice work, You made the pcb yourselves ?
regards
kp93300
Old 17th February 2013, 04:52 AM   #173
No, I did not make the boards but I did the layout, soldering, etc.
The other thing I did not do was mil the 1mm recess in the bottom of the heat sink...CNC guy did that for me.
Sounds great...(IMHO)
Old 8th March 2013, 08:40 AM   #174
Hi KP, have you received you board and listened to it. What do you yhink, also any mods in mind for it.
tabarddn
Old 12th March 2013, 06:46 PM   #175
. Will report back in about 2weeks from now. Received the mic board just before I went travelling
Old 29th March 2013, 08:39 AM   #176
wushuliu's Avatar
I just asked Cristi of Connexelectronic if he would consider designing an amp based on the new TPA chips. He just replied that he would consider designing an amp, possibly with onboard smps which is his specialty. I've used several of Cristi's amps, they are very very well designed and he has many happy customers. I suggest anyone interested in these TPA chips head to the Class D Connexelectronic forum here to let him know there is interest for such an amp!
Old 29th March 2013, 10:05 AM   #177
norman bates's Avatar
cervelorider (posts here) built me a tpa3100 amp (parts express board), I'm sure he'll build you one too.
Here is is very nice website.
http://www.fleawatt.blogspot.com/
But I think he's moving on to tpa3122 now.
I just hooked mine up this morning.
FLEAWATT : Fleawatt Cigar Box Amplifier
I'm using it with a revealing 110db jbl 2407 compression driver on a nice round mcm horn (54-580).
Has anyone bridged the 3110 ?
Seems to me the lack of output filter (only ferites) goes a long way on improving the sound vs a 12 or 18db filter with their numerous parts.
Norman
Old 29th March 2013, 12:01 PM   #178
xrk971 is offline xrk971  United States
xrk971's Avatar
Norman,
Cervelorider makes nice stuff and is a great guy. I think the 3110 is designed for ferrite bead chokes if the speakers are very close to amp with short run of like a foot (like a boom box). I think their literature says to use a real wound inductor and capacitor and resistor network filter for long runs up an external speaker. Also, I think it is bridgable but not sure if the Sure board is set up to allow that. How does it sound with your CD and horn setup?
Old 29th March 2013, 03:01 PM   #179
tpa3110 is already bridged. Tpa3116 and Tpa3118 are both the same chip, one with heatsink pad up allowing adding of heatsink above chip and other using pcb for heatsinking thus the lower power ratings. Thats why I said you already built tpa3116 since your dead bug chip was upside down with heat pad up.
tpa3130 is lower current version more suitable for 8 ohm loads.
Old 29th March 2013, 04:45 PM   #180
xrk971's Avatar
Capt Grogg,
You are serious? The difference is in the orientation of powerpad only? That may not be true because the letter designations following the chip number DAP (down) vs DAD (up). Why didn't they just call 3118D2 the 3116D2DAP? Neat if so, I can say I know what the sound of the 3116 is like - the same!
Troubleshooting TI Class D EVM amp? fizzsweden Class D 4 18th July 2011 09:29 PM
Volume control for class D audio TI-600 amp subwerker Class D 2 13th June 2011 09:11 PM
TI class d eval kits Tekko Class D 16 14th August 2010 04:17 PM
FS: Class-D TI TAS5010 & TAS5112F2 Evaluation Board ralphs99 Swap Meet 7 24th March 2009 11:21 PM
Class D amps using TI chips? picklgreen Class D 0 7th January 2007 12:20 PM
Copyright 1999-2017 diyAudio
