TI TPA3100D2, Amazing Class D Amp
Old 13th September 2012, 02:49 AM   #91
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Those are the shielded bobbin core inductors for the outputs.... 33uH.
Old 13th September 2012, 02:53 AM   #92
kp93300 is offline kp93300  Malaysia
Originally Posted by rsavas View Post
I am using a 12V/1500mA Walwart and on the pcb I have one 4700uF/35V VZ Nichicon, then two of 220uF/35V Silmic II Elna, one per channel!! Good choice it seems.
I have not tried this configuration with my 15" sealed speaker units yet. The amp is not intended to drive 15" bass units. A bridged configuration would be preferred in this regard, then beef up the reserve capacity some more.
Hi I saw your board in the previous post. looks very complex.
can your board be adapted for a simple amp as in the evaluation board ?
kp93300
Old 13th September 2012, 03:01 AM   #93
rsavas is online now rsavas  Canada
They are the inductors,33uH, used in filtering the switching transients.
Old 13th September 2012, 03:01 AM   #94
gilesw is offline gilesw
Doh, I didn't see the chip had a dot in one corner. So it looks like you're right on those caps. How do you know what UF to choose?
Old 13th September 2012, 03:07 AM   #95
Here's a better photo I took :-
https://plus.google.com/photos/11599...COqqr4HmqtOUcQ
Old 13th September 2012, 03:09 AM   #96
I do not have any formula to calculate the optimum value of c21, 22. i tried 470 uf and 1000uf in parallel with the existing 220 uf. 1000 uf wins .
Old 13th September 2012, 07:40 AM   #97
keith_correa is offline keith_correa  India
Hi kp:
What PS are you using for this eval board to your sonic satisfaction?
Old 13th September 2012, 07:53 AM   #98
I have access to a Meanwell SP-150 SMPS which has 24VDC output with 6.3A. The eval board specifies current at 4A max. Does this mean that I cannot use this SMPS to power up this eval. board??
Old 13th September 2012, 07:57 AM   #99
Kjeldsen is offline Kjeldsen  Denmark
No, your can't draw more that 4A out of the Power supply. You supply just can't be below 4A (it can probably because normally you will only use 1/8 of the power continuosly, and then have some peaks reaching 4A)
Old 13th September 2012, 08:12 AM   #100
Originally Posted by keith_correa View Post
Hi kp:
Hi Keith,
I tried 2 SLA battery wired in series for 24 V and a 20 V laptop 4A smps filtered by a few motor run caps
I preferred the later. There is no cap filtering in the SLA set up.
SLA is clean but music lack dynamic contrast .
regards
kp93300
TI TPA3100D2, Amazing Class D AmpHide this!Advertise here!
Troubleshooting TI Class D EVM amp? fizzsweden Class D 4 18th July 2011 10:29 PM
Volume control for class D audio TI-600 amp subwerker Class D 2 13th June 2011 10:11 PM
TI class d eval kits Tekko Class D 16 14th August 2010 05:17 PM
FS: Class-D TI TAS5010 & TAS5112F2 Evaluation Board ralphs99 Swap Meet 7 25th March 2009 12:21 AM
Class D amps using TI chips? picklgreen Class D 0 7th January 2007 01:20 PM
