WIRING HELP for a Super Duper Nice Girl ;)
Old 25th July 2012, 09:41 AM   #31
kittygirl is offline kittygirl  United States
Underwurlde, you are the best!!! Thanks for taking the time to explain that.
I had to read that like 3 times, LOL. I guess I will just try them both and report back.
Well I found these....... that seem like a great deal
http://www.taydaelectronics.com/3-5m...ed-socket.html
6.35mm 1/4" Mono Chassis Socket / Jack
Thank you, thank you, thank you!!!!!
Old 25th July 2012, 09:59 AM   #32
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Be careful with that type 2 power supply. It is most likely unregulated and rated for 12V at a specific current draw. The unloaded voltage can be much higher and you run the risk of frying that poor little chipamp.
Old 25th July 2012, 10:16 AM   #33
Well that doesn't sound good. Is there a way to tell from the specs if this is safe to use on this little amp?
I just took a picture of the tag on the transformer and have attached it.
Here are the specs written out
GlobTek Inc.
Class 2 TRANSFORMER
CLASS 2 NOT WET. CLASS 3 WET
P/N WD1E2000S760K-N
MODEL : GT-357-12-2000D
INPUT: 120V AC 60Hz 35W
OUTPUT 12V DC 2000mA
UL US LISTED
Looks to be Center Positive
File Type: jpg $(KGrHqV,!l8E8(C6O,6SBPd3vYnzJQ~~60_12-1.JPG (138.6 KB, 97 views)
Old 25th July 2012, 10:20 AM   #34
underwurlde is offline underwurlde  United Kingdom
^ Just a warning from TheAnoymous1, just in case & he was quite correct to make you aware of that - lots of different ways to make a power supply: some good, some bad. That is not to say ALL "Type II Transformer" PSUs are inherently 'bad', BUT some could be!
Anyway, it's far easier for you (IMHO) to change that mono jack plug on your guitar to a stereo one, but if you REALLY don't want to go this route then...
Hopefully I have this right:
You'll need now a DPDT (Double Throw, Double Throw) switch to do what you want.
Andy
PS, Hawaii??? Lucky, lucky!
"Summer" (I use the term lightly) here in the UK has so far consisted of 3 months of solid rain. Sunny today though, but at work
Old 25th July 2012, 10:55 AM   #35
Andy
ANDY.......
Again, wow, you are so quick to respond, and again sooooo incredibly insightful and informative. Thank you for taking time out of your day to draw up this diagram. I can't thank you enough, I wouldn't have known where to begin.
A question.... so from your diagram I need a 1/4" STEREO jack
6.35mm 1/4" Stereo Chassis Socket / Jack 3 Terminals
Not a Mono jack like I was thinking
Is that right?
I appreciate TheAnonymous1 warning me on the Class 2, I definitely don't want to fry the board.
Yup, I am an Island girl, born and raised. Aloooooha.
3 month of rain, then working on a sunny one, yuk. I am sending you some sunshine love from Hawaii!!
Old 25th July 2012, 11:06 AM   #36
"Is that right?" Yes.
My thinking is for you to keep everything STEREO (and why not?) and ONLY when you plug your mono-forcing guitar mono jack plug in, then flick the switch to put it into mono enabled input mode, but with 'mono sounds' coming out of BOTH speakers.
Andy
Old 25th July 2012, 11:28 AM   #37
And if using screened cable to wire this lot up, then:
Andy.
Old 25th July 2012, 11:54 AM   #38
chris661 is offline chris661  United Kingdom
chris661's Avatar
We've had warm and humid for the past few days now. The rain's arrived and the air is starting to clear. Lovely.
About power supplies...
I have the same amplifier board as the one you're using. I found that using a 12v (can't remember if its transformer or switch mode) wall supply gave a high-pitched whistle sound from the speakers. I suspect the switching frequency of the amplifier was interacting with the power supply. Its worth measuring the output of the power supplies before plugging them in - I have a (different) 12v supply that's more like 19v off-load. This would make the amplifier very unhappy, and the magic smoke may come out.
If I had to bet on one of them, I'd go for the switch mode one - its more likely to be regulated.
I also use 7.2v remote controlled car batteries to power mine - no whistling sound, and one charge will give ~2 hours at rather loud levels. >4 hours if the volume's at a more sane level.
Another thing!
Watch your speaker impedances. My amplifier is driving a 4ohm speaker per channel, and (when cranked right up) cuts out when bass comes along: it detects too much current (or maybe heat), and shuts down.
Have fun, though - these are really cool boards to play with.
Chris
Edit
Originally Posted by heyduard View Post
Wow! that's a great buy. Better buy two or more. At $7 a pop, the QA/QC dept won't be well funded.
Let us know how these amps rock.
They're decent enough. Get an off-the-shelf bookshelf speaker, put one of these in, add a decent battery and you've got a decent (plenty loud) portable speaker.
Old 25th July 2012, 12:30 PM   #39
Mooly's Avatar
Originally Posted by kittygirl View Post
Thanks Mooly!
I just realized I have 2 power supplies, I don't want to cut both of them.....Sooooo, i am wondering which one I should use.
One says "Switching Power Supply"
One says "Class 2 transformer"
Any advantages/disadvantages to using one over the other?
How do I determine correct polarity?
You've had plenty of replies I see... some good advice there.
A meter (DVM on volts) will show the polarity. Always check polarity before powering up the amp by measuring the voltage with the PSU unconnected to the amp.
If the meter reads say 12.7 volts then the PSU lead that the Red meter lead goes to is positive. If the reading was -12.7 then the DVM is showing that the Black meter lead is connected to what is really the supply positive. Obviously make sure the meter leads are correctly fitted (right way round) first
A non technical way of determining the type of PSU is to go off its weight. A 12 volt 2amp SMPS will be light (like a laptop PSU) and a 12 volt "linear" type with conventional transformer will be much heavier.
An SMPS type is usually tightly regulated and the voltage is the same at no load or full load.
A linear type without regulator will show a higher voltage when no or little current is drawn.
Old 29th July 2012, 08:05 AM   #40
The wiring diagram worked perfectly!!!!!! THANK YOU, THANK YOU, THANK YOU!!!
Ok, so i just received a few more of these little guys. I also have some leftover parts from Radio Shack because I couldnt wait to get started on this one.
I have 3.5mm jacks and wire. I don't have a prewired 3.5mm audio cable that I can cut like I did for the first one. So I have a couple of questions about wiring the 3.5mm 1/8" jack.
On this board is a mounted 3.5mm jack with 5 pins. Like this one
10 Pcs DIP PCB Mount 5 Pins Female 3.5mm Stereo Audio Jack Plug Socket | eBay
The ones I bought from Radio Shack are 3 pins. Like this one
Lot of 5 Stereo 3.5mm 1/8" Panel Mount Jack | eBay
I have wire and I can't seem to figure out which wires go to which pins to make it work on both channels.
I assume I would only have to hook up 3 wires. Or do I have to run jumpers to the remaining 2 pins to make it work?
Thanks in advance
Kianna
WIRING HELP for a Super Duper Nice Girl ;)Hide this!Advertise here!
Super-Duper-Uber Capacitors On The Way!! valveitude Everything Else 16 25th February 2013 08:30 PM
Super nice Bryston 3B Amplifier for sale adowd Swap Meet 7 17th June 2010 10:08 PM
super nice carver home stereo amp on ebay scottericsonon Swap Meet 0 19th November 2007 04:38 AM
super duper newbie questions M5150 Multi-Way 13 9th February 2002 02:47 AM
