What are these board mounts called?
Old 3rd July 2012, 08:58 PM   #1
torclausen is offline torclausen
Default What are these board mounts called?
Hello,
I've been having great success with hong kong class d amplifiers (2020, 2050 and the like). Some of them come without an audio input, but rather this strange white plastic snap with prongs. In this case, for both the power connection, as well as the audio input.
What are they called, and where can I find the male component? I especially would like a 3.5 headphone jack to mount in the three prong one.
Thanks so much!
Tor
Old 3rd July 2012, 09:03 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
They are made by a company called JST. Pretty common connectors, once you start browsing catalogues/shops you should find them easily. You need the housing and crimp sockets, also the special crimp tool as they can be pretty fiddly to do. You may get away with a cheaper generic crimp tool rather than the expensive proper one.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 3rd July 2012, 10:08 PM   #3
so, I seach for jst? "jst, audio jack?" Are they on ebay?
Old 3rd July 2012, 10:19 PM   #4
Did it Himself
They are nothing to do with audio, look under PCB header.
Old 4th July 2012, 04:39 AM   #5
In this case I believe they are... Its ground, left and right. The other little plug is power. Other than that, there is only speaker outs.
Old 4th July 2012, 06:15 AM   #6
benb is offline benb  United States
The connector may carry audio on this board, but it's manufactured and sold as a general electrical connector, not one made specifically for audio. You won't find this or its mating connector if you search for an audio connector.
I've seen these on computer motherboards and expansion boards and such, for things like cooling fan power connections. If you have an old computer gathering dust in the basement you might open it up and see if it's got a connector you can use.
I'd guess Molex, among other brands, makes these, but Molex makes thousands of types of connectors. See if you can find it in the connectors on digikey.com or mouser.com.
Old 4th July 2012, 06:47 AM   #7
Boscoe is offline Boscoe  United Kingdom
You need to measure the pin spacing once you have determined that search for either 2mm or 2.54mm depending on what you measure and then 3 way JST connector.
Audio projects and more: gswdh.co.uk
Old 4th July 2012, 08:20 AM   #8
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I would remove the connectors and just hard wire the off-board components and psu.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 5th July 2012, 03:12 PM   #9
qusp is offline qusp  Australia
qusp's Avatar
^^ this, those JST are only JUST high quality enough for low current auxiliary power, I would never use one for carrying audio, its contacts are the crappiest of crappy tin plated brass/copper alloys... if you are lucky.
I would even use something else for a battery connector, truly bad connectors. its a JST XH, XT or other X series, looks 2.54mm variant.
also the onboard connector you have there IS the male connector (notice the pins) you are looking for the female if you persist with using them
Old 5th July 2012, 05:43 PM   #10
thanks folks, that helps a ton. I don't make these things... just trying to deal with it.
What are these board mounts called?Hide this!Advertise here!
Universal Mounts or w/e that means... Bose(o) Construction Tips 1 2nd December 2009 08:14 PM
small display mounts Phatriff Parts 2 13th October 2007 10:54 AM
isolating mounts for transformers drembo Tubes / Valves 2 15th September 2003 10:42 PM
S-video chassis mounts? Arbury Everything Else 4 14th January 2002 09:08 PM
