IRS2092 shorts when connecting IRHI2019H
Old 30th June 2012, 08:55 AM   #1
outercript is offline outercript  Mexico
Default IRS2092 shorts when connecting IRHI2019H
I have been designing a class D amp based on the IRAUDAMP7S rev 1.0 and I cant manage to make it work.
It seems that when the MOSFETs are connected the power supply shows as being shorted.
What are the things that could cause this? I have checked for shorts in pcb, modified dead time and didnt seemed to help.
Thanks in advance =)
Edit: Typo mosfet is IRFI4019H
Old 30th June 2012, 05:52 PM   #2
electroconico is offline electroconico  Mexico
Hi
Do you have a oscilloscope ?
If yes , upload you captures.
If not , try to get one .its essential.
Also I'm working on class d amp based iraudamp.
Before connecting the mosfets check every signal.
CSD
VAA
VSS
Supply rails ?
Im using irfb4212 +-35vdc
This link may help you
Old 30th June 2012, 09:10 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
The 2092 definitely works with those mosfets so you must have made a mistake somewhere. I have built around 20 2092 amps and had no problems so it is fairly reliable.
Are the mosfets connected correctly ?
Did you use the datasheet for your circuit ?
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/itm/253272755...84.m1555.l2649
Old 1st July 2012, 06:07 AM   #4
Yes I have an oscilloscope, I managed to make the circuit to work but driver outputs are always off.
Two dual power supplies are being used (each one with outputs at 25V) to have +/-50V in power rails.
Mosfets and driver are always cool, so it seems to be a problem with decoupling. But Im not sure what to do....
It might help but in stanby circuit draws about 10-20mA from the power supply.
I attach photos of the pcd, and the schematic I have used. It should be the same as the one in IRAUDAMP7S rev1.0 but different LPF component values.
Old 1st July 2012, 12:10 PM   #5
SNY is offline SNY  Hungary
Default pcb
PCB Layout completely wrong ...
A Class D amplifier requires a much better PCB Layout.
Old 1st July 2012, 04:14 PM   #6
Any advice on making a good pcb? Whats wrong?
Old 1st July 2012, 06:57 PM   #7
Take a moment to read this document AN-1138
Try to improve your pcb layout,as a reference you could use the iraudamp7D.
If there is not output signal you should make a double check on pin voltages.
Old 2nd July 2012, 03:01 AM   #8
The easiest way is to use a pcb layout and circuit designed by IR.
There are some in the data sheets.
It took me a few revisions before I got a pcb to work, even then I had to scale back the voltages for over current to get it to work loud enough.
Decoupling is vital as close to the mosfets and IC as possible.
Tracks need to be as thick and as short as possible.
IRS2092 shorts when connecting IRHI2019HHide this!Advertise here!
Testing for tube shorts Zero Cool Tubes / Valves 3 31st May 2008 09:48 PM
Basic measurement question re: shorts pjanda1 Tubes / Valves 10 19th May 2008 03:21 PM
Canadian Government buys four used subs, one shorts out. rcavictim The Lounge 37 28th October 2004 11:01 AM
Copyright ©1999-2017 diyAudio
