Replacing My Memphis Audio ST-1000D blown output transistors. HELP!!!
Old 29th June 2012, 12:46 AM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Does the fuse pop when remote is activated, or even with open remote?
I recommend you to get or borrow a current limited 12V supply, something that can do 10-25A and then fold back to avoid damage. After repair, doing the first test directly in the car is not a good idea, doing it in a work bench is much better.
I use to feel like the small child in The Emperor's New Clothes tale
Old 30th June 2012, 12:10 AM   #12
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
You need to check all transistors for shorts in the amplifier.
Output transistors failing will often take out the power supply transistors too if the fuse doesn't blow quick enough or the protect is too slow.
Just to complicate things I have seen blown output transistors taking the class d IC with them.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/itm/253272755...84.m1555.l2649
Old 18th July 2012, 05:46 PM   #13
ALLMemphisCarAudio is offline ALLMemphisCarAudio  United States
Is there anyone willing to take the time to actually fix this amp for me PLEASE! I made an agreement with the wife that I would only reinstall this amp back into my car if I could fix it myself! That means I have a VERY limited budget but I know that there is only a bad resistor or transistor that's causing the red protect light to come on! I just don't have the knowledge or time to learn properly to get this amp working again and re-installed by the end of car show season! Please send me offers through a message. thanks
Old 27th September 2012, 03:58 AM   #14
Ok, so what are the parts labeled KO304 and KO307, voltage regulators? I was wondering what the possibility of these being burnt when the power FETS when out?
Also, if the through holes for the transistors lost their solder eye-lits when I was desoldering the old ones, can I solder the legs to the nearest solder point in that same area? For example, the first leg of the power FET connects to the gate resistor so can I solder a joint from the first leg directly to its cooresponding resistor?
Replacing My Memphis Audio ST-1000D blown output transistors. HELP!!!Hide this!Advertise here!
memphis 1000d timwebb Car Audio 36 29th August 2011 12:30 AM
1000D Memphis Amp ? Hoppy72450 Car Audio 9 23rd April 2011 05:07 PM
another memphis 1000d timwebb Car Audio 3 11th April 2011 04:14 AM
Memphis 1000D transformer. tgdrums1990 Car Audio 4 16th June 2010 04:32 PM
Memphis 1000D Transistor Blowing jf8620 Car Audio 46 12th March 2006 11:49 PM
Copyright ©1999-2017 diyAudio
