Sure TK2050 voltage help.
Old 6th June 2012, 11:10 PM   #1
Jezz is offline Jezz  Denmark
Default Sure TK2050 voltage help.
Hi all
Im building a mobile soundsystem, it's running 12v with solarcells on top, cell phone charger and lots of cool features..
Anyway, I bought the Sure TK2050 4 channel 100w amplifier and recieved it last week.. As far as I understand the amp will function within the range of 10-30V, but ideally it should run in 24V.
The specs on the amp in 12V is not clearly stated anywhere on the internet, and since the rest of our setup is in 12V, can anyone explain how the amplifier performs with 12V vs. 24V, in regards to power consumption, output W etc.
Alternatively we will need some kind of 12V->24V converter, but before I spend money on such a thing, I would like to know the difference between providing the amp with 24V compared to 12V
If case is I must buy a converter, how many ampere must the "output current" be for my amp?
Best regards.
Old 27th July 2012, 11:08 PM   #2
speakerdonk is offline speakerdonk
BUMP.
Im looking for answers for the exact same Questions...
Anyone:-)?
Old 7th August 2012, 12:35 PM   #3
Speed.Cat is offline Speed.Cat  Germany
it performs best around 30V.
(less Vin means less powerful, less loud, but also less consumption)
so if you have a 4x100W amp it will drag (with 90% efficiency) around 500W (max)
is your powersource big enough to deliver that? otherwise you can just convert what you have.
the math:
12V 33A =400W
30V 13,3A =400W
but if you have 12V with just 5A =60W total
realistic it will be around 54W....which is 4x 13W output
Old 7th August 2012, 12:44 PM   #4
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
less V = less W (means less powerful, less loud, but also less consumption)
the math:
12V 33A 400W
30V 13,3A 400W
444W. But that's RMS. It will be around 56W drain with actual music sources.
Sure TK2050 voltage help.Hide this!Advertise here!
TK2050 vs TAS5630? JWMortensen Class D 20 13th May 2013 03:43 AM
TK2050 with sub? rossi Class D 3 28th May 2011 07:08 AM
What TK2050 amp? Commited Class D 5 23rd March 2011 02:53 AM
TK2050 Amp kunalraiker Class D 4 24th November 2010 03:18 PM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
