| Class D Switching Power Amplifiers and Power D/A conversion |
#2 |
The seller is as confused as I am as to why it isn't working. I'll send this board back and get a replacement...
#3 |
I ordered this same board and encountered the same problem. First thing I noticed when hooking up the board was the single ground wasn't tied together at all. I ran a jumper wire between the two grounds on the signal input and this greatly reduced the hum. It is still audible when the amp is powered on and volume is all the way down but you cannot hear it once you turn it up. So, the ground between the audio input not being shared is my best explanation for this problem. I will muster up a better fix shortly.
#4 |
Bottom line, something is horribly wrong with the layout of that board. Get money back rather than a new board, especiazlly since your not the only one encountering the same issue.
I'd say whoever cadded this board made an error somewhere, meaning the entire batch is bad.
The point of life is to build atleast one audio amplifier before you die.
| Little BTL Amplifier - ZIPPO BTL | MoonL | Headphone Systems | 13 | 13th May 2012 01:06 PM |
| BTL TDA7294 | doditsuprianto | Solid State | 1 | 22nd May 2011 07:10 AM |
| TDA7294 in BTL | Einric | Chip Amps | 4 | 26th February 2011 02:38 PM |
| TA7250BP BTL IC amplifier problem | h3ad | Chip Amps | 4 | 24th October 2007 01:14 AM |
| ultra-BTL | digi01 | Chip Amps | 1 | 16th March 2007 02:37 PM |
