Best TK2050 assembled board? - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th May 2012, 08:51 AM   #21
You don't need to worry about grounding issues. Just earth the meanwell unit as usual.
Regards.
Michael
Old 16th May 2012, 12:17 PM   #22
Well that's the issue. What's "usual"? I've never earthed anything in my life....
Edit: Do you mean connecting back to the "earth" of the mains socket? Is it necessary to ground the chassis for safety as per this diagram?
Or is that only necessary for a linear supply?
Old 16th May 2012, 01:31 PM   #23
The Meanwell unit has three input connections from the mains AC: Live, Neutral, Eath.
It has two DC output connections: V+ (positive DC), and V- (return DC).
Actually there are three sets of each DC output to allow for easy wiring of multiple recipients (at the same voltage).
Have faith. Its simple. No humming issues with mine. No need to earth amp unit itself. Have a look at the picture.
Meanwell NES 350W 36V
Regards.
Michael
Old 16th May 2012, 01:33 PM   #24
In Denmark where I live, I can only connect Live and Neutral. What to do with earth?
Old 16th May 2012, 02:05 PM   #25
Thanks Michael,
That does seem pretty straight forward. I may give this a go after all.
Old 16th May 2012, 02:05 PM   #26
I am not sure.
Ignore it?
Other non-earthers may offer advice.
Regards.
Michael
Old 16th May 2012, 02:37 PM   #27
I'm now thinking of going the whole hog and building with the T4 using the SMPS300R 48V 230V power supply.
Is it more risky using the naked psu over the meanwell? It looks like it has screw input and output connections as well?
Old 16th May 2012, 03:17 PM   #28
Go for it.
It is all plug and play really. So long as the modules are covered up for normal use, the "nakedness" will make no difference.
Good luck
Regards.
Michael
New TK2050 board hifimediy Class D 2266 18th December 2016 05:06 PM
7.1 or 5.1 TK2050 8-channel amplifier board col Class D 2 27th October 2011 09:58 PM
2X50Watt TK2050 board aussiebuddha Chip Amps 7 14th July 2011 09:54 PM
Fried TK2050 Amp Board Rikdee Chip Amps 2 18th May 2011 06:45 AM
Help with Helder TK2050 board mixmechanic3 Class D 3 9th January 2011 04:27 AM
Copyright 1999-2017 diyAudio
