Volume control by adjusting Voltage
Old 8th May 2012, 07:36 PM   #1
pinobot is offline pinobot  Netherlands
Default Volume control by adjusting Voltage
Hi.
I'm new to this diy amplifier stuff and i'm looking into buying my first T-amp. Now it seems you can change the gain by adjusting the voltage, but why isn't that done, are there sonic disadvantages and what are they?
Old 8th May 2012, 07:51 PM   #2
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Which voltage do you mean?
The supply voltage?
jan didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 8th May 2012, 08:07 PM   #3
Yes
Old 9th May 2012, 12:58 AM   #4
wwenze is offline wwenze  Singapore
If gain changes with supply voltage, any noise on the supply rails will show up on the output.
Old 9th May 2012, 04:11 AM   #5
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
To clarify the above, no, the supply voltage does not affect the gain. Feedback defines gain. Look up basic op-amp calculations to get an idea of how that works.
The power of Science compels you!
Old 9th May 2012, 04:25 AM   #6
Capt Grogg is offline Capt Grogg  United States
Open loop class d amps change gain with power supply voltage change, power supply sag causes compression, noise also goes down with voltage. Lots of oportunities and yes instead of power supply rejection you get power supply injection. Used in many commercial products, including top of the line Sony multi-channel receivers
Volume control by adjusting VoltageHide this!Advertise here!
Adjusting ELS hybrids by changing the voltage ljpp Planars & Exotics 30 22nd September 2012 08:55 AM
simple question: is midpoint voltage setting for adjusting the DC Offset? Arnie75 Class D 7 29th April 2012 10:54 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
Variable Voltage Volume control jkeny Power Supplies 4 10th February 2008 09:13 PM
adjusting step of remote contoled volume? sapek Parts 18 2nd January 2008 12:24 AM
