high frequency switching tone reaching speakers - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 19th April 2012, 12:44 PM   #1
Default high frequency switching tone reaching speakers
Has anybody found that the speaker output of most class d amps shows a blurred line, caused by hf remnants getting past the amp's filters. This I found was the main source of listenting fatigue. I was able to reduce this and create a more relaxing sound by more filration after the output, like a low pass filter with a high operating point. This effectively leaves the amp working into high impedance at high frequencies. Switching my scope to see the carrier waveform I found pure sinewave in my prototype Tripath and my little T-Amp but a ragged sawtooth on my current project using IRAUDAMP modules. (zoe tsang variety). Can post filtration like this upset the amp's operation?
Old 19th April 2012, 01:50 PM   #2
Ouroboros's Avatar
You will always see the carrier residual waveform on the output waveform. What is your switching frequency? Any second-order low-pass filter you add to reduce the carrier level by an appreciable amount will have the -3dB point at a frequency low enough to raise concerns about it affecting the frequency response of the amp with non-resistive loads.
Old 19th April 2012, 01:51 PM   #3
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
No necesarilly. I used 4 pole Butterworth filter, and in a 4" cone tweeter didnīt listen any rare.
Some residual HF allays be there, infinite attenuation doesnīt exist.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 19th April 2012, 02:33 PM   #4
Boscoe is offline Boscoe  United Kingdom
Higher order filter means more components and higher series resistance so bass will be sacrificed quality wise...
Audio projects and more: gswdh.co.uk
Old 19th April 2012, 05:06 PM   #5
I,m taking about a two coil and two cap filter. Which is the difference: tenths of milliohms? They donīt care. I canīt see how a .01ohm coil may be worst bass notes, and not middle and treble ones... In the worst case, there must affect more treble because of increased frequency and more eddy and hysteresis currents in core.
Old 20th April 2012, 06:47 AM   #6
ronte is offline ronte  Sweden
I'm not shure that PWM residual actually influenses the sound, I'll try my idea of thinking with you guys here .
If you feed the speaker with a unfiltered PWM signal, the speakers still produces sound, and to my hearing not different to with a filter. I think that the PWM signal actually controls the "cones" the same way as a pure sine. If you think of the speaker as a motor, instead of control the speed and direction of the motor with DC (alternating direction and voltage), you direct it with pulses (PWM). As long as the switching freq is fast enough, no distorsion would occur in the speaker (the cone can't move fast enough to convert the switching freq to sound)...
What I don't have ideas about, is how the signal is handled by the speakers passiv filters, but it seems like they behave as if their where fed with a sine signal. (I've tested just to see if I could here any difference with or without a filter, and to my ears it's, if any different, more "clean"). I think that the actually only benefit of the filter is to minimize RF, and any "residue" of the PWM isn't harmfull (this will still only be handled by the speaker as the sine signal it's representing).
Any thoughts?
Old 20th April 2012, 07:28 AM   #7
I could agree with that as along as the switching frequency is high enough.
Old 20th April 2012, 03:36 PM   #8
Default switching frequency reaching speakers -
Thanks everybody for a superb response. I have establshed that there is no operational reason why additional deep filtering should not be added but we seem to be split on the sound quality benefits. I say it improves and the reason for this was on building my first class T amp using a prototypr board I quickly became dissatisfied with the sound. I had a conversation with the supplier about what could be 'wrong'. I described the sound as if some background noise was present but was being drowned out. I then dragged my old scope from the attic and found the hf carrier at the speakers. It was indeed background noise that could not be heard. I used valves for a while then by applying filters to my class T I made it come clear. The difference in opinion may be the type of listening. Mine is classical but for pop and movies class D amps may fare better.
My current project involves 6 channels and active filtration (3 way stereo). The idea was to eliminate the high power crossover, so I now find I need an ..er , crossover.
what irony!
Old 21st April 2012, 04:18 AM   #9
Did you measure this with a microphone?
Old 21st April 2012, 09:34 AM   #10
I didn't measure with a microphone. I probably wouldn't pick anything up at 400kHz anyway. I believe that the problem is not at 400kHz but at lower frequencies. If you superimpose 40kHx over the 400kHz switching tone you will get nice harmonic undertones as the two frequecies 'knock' together. If you do the same with two tones not mathematically so related, say 43kHz then you will get a rough unharmonic sound with odd harmonics. I think this is why digital amps seem to suit films and grungy pop but not natural instruments with purer tones.
Jus for info, I'm including photos of my scope screen (vintage Heathkit 1960 still going strong). top trace (no 1) Click the image to open in full size. shows the carrier by itself. trace (no 2) shows the carrier waveform ( same as 1 but expanded scale, showing distorted sawtooth waveform, finally trace (no 3) shows an audio signal playing comfortably load over the carrier. Here the carrier is 'louder' than the audio signal.
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
How to identify max switching frequency of a MOSFET jegandren Power Supplies 8 17th July 2008 07:12 PM
mhz switching frequency lumanauw Class D 40 24th December 2007 01:48 PM
Hysteretic self-oscillating amplifier with constant switching frequency sovadk Class D 8 18th November 2006 10:44 AM
Hysteresis Controller with constant switching frequency TOINO Class D 4 18th June 2006 08:34 PM
Copyright Đ1999-2017 diyAudio
