LDR Limiter for TA2020, TA2024, spirited playback without clipping.
Old 13th April 2012, 08:47 PM   #21
dangus is offline dangus  Canada
I believe it's an overload pin which activates when the amp clips. IIRC it's not suitable for driving an LED directly; I'd use something (4538 monostable multivibrator?) to stretch the pulse so an LED would stay on long enough to be visible. It's been on my roundtoit list to make up a little board for that purpose. You could use that buffered output to drive an integrator which would then drive the LDR. I'd be tempted to use a VCA for the gain element, like the SSM2164 (quad VCA). It looks like those are still available (AD says "last time buy"). Or the SSM2018T (single VCA); those are still listed as "production".
Old 14th April 2012, 09:03 AM   #22
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Ah, yes. The "clip something else" approach. I do favor that. The limiter in post one is already running just fine in several locations around the globe; however, we are in need of a high speed soft clipper, using something much faster than an LDR.
Old 15th April 2012, 02:29 AM   #23
If this was set for "fast attack", "slow decay", it would automatically turn down the volume at the first sign of clipping. Maybe not what you're looking for, since that wouldn't be as loud overall compared to gently clipping those peaks.
Old 15th April 2012, 04:08 AM   #24
For small scale amplifiers here are constraints for limiter:
Not catch the amplifier on fire. (observe current max)
Not make any sudden changes or noises. (must constrain extent)
Not decrease the bass output at all. (must avoid fast attack)
Just bear in mind that these circuits are interoperable with additional circuits and that any single effect must be constrained so that it is unnoticeable (transparent) in order to avoid sudden noise. But, you can indeed run multiple mild effects simultaneously if you wish to do so. For example, an extremely high speed soft clipper could be run on the same amp as the nice sounding limiter shown in post 1 and thereby provide a somewhat more complete feature set, since you would have both fast and slow features without removing output power. As a bonus, that combination will provide on-the fly "unclipper" audio restoration, but only when the amp is near max. That's right, it would soft clip a modern studio clipped source track, thus restoring it on-the-fly by removing the clipping prior to amplifying. That's a bit more fun to crank up.
P.S.
The limiter's constraints/parameters are much different between overpowered amplifiers versus underpowered amplifiers.
Old 25th April 2012, 01:13 AM   #25
Another type of diode that works well for this application is the MR. The MR diode is a great help in mobile LED lighting refits because of its flexible switch on point. It actually switches on at 0.47v but will drop up to 0.75 with just a little bit of current (quite useful when in series). In this behavior, a big MR is much like a little schottky; however, the MR gives you a different voltage selection to choose from.
I tried substituting it instead of the schottky in post 1, and the MR worked. . . a little bit better. The transparency very similar; however, I thought there was subjectively a bit more bass. It was hard to detect any difference, therefore it worked well.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 5th May 2012, 09:28 PM   #26
keantoken is online now keantoken  United States
keantoken's Avatar
Try using a 2nd-order LP filter before the LED, or even third-order. This way, the high internal resistance of the 22uF lytic won't cause significant signal coupling to the LED, adding distortion to the signal, and filtering will be much more effective. If a transistor were used to drive the LED, smaller film caps could be used, though larger low-ESR lytics might work just as well considering there is no shortage of drive from the rectifier and amp output.
I don't have any subjective experience with any kind of sound limiter, so this is just based on my knowledge of electronics. I'm speaking from the standpoint of the coupler adding distortion as the rectified audio signal passes through it. I think you should experiment more with the LP filer, as I think it will have a larger impact on the sound than anything else.
Also, if the amp blows up and hits the rails, the LED or 390R resistor might be destroyed. A depletion FET could be placed in series with it for this purpose, to limit the LED current.
If there is DC across the input, the varying LDR resistor will add subsonic rumble when the circuit is activated. A capacitor in series with the LDR resistor may prevent this; moving the LDR after the amp's own DC coupling cap will only ensure a DC offset across the limiter because of the amp's input current. Maybe this rumble is a non-issue however.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 5th May 2012, 09:32 PM   #27
keantoken's Avatar
Also, putting the negative end of the 22uF cap after the 390R resistor may increase filtering, as the impedance of the LED will raise the corner of the LP filter, nonlinearly with increasing LED current. Including the 390R resistor this way may help to stabilize the LP corner.
Old 6th May 2012, 04:35 AM   #28
Thank you!
A good limiter, such as post 1, cannot "add" distortion since good signal does not pass the knee voltage of the detector, thus the circuit is off. . . until the amplifier starts to clip. Engagement of these devices should occur only "instead of clipping" and therefore it is a noise reduction device.
It is feedback, albeit tardy, and the lateness allows a slight clip and full bass impact shortly before clipping is temporarily disallowed.
There are adjustments/parameters:
There is extent (the input voltage divider), there is treble versus bass balance (that 22uF slows it down for clean treble) and there is engagement point (the sloppy knee voltages of LED and schottky help transparency).
I would love to hear more about employing the depletion FET! That could really help when setting parameters for larger amplifiers that would be strong enough to break the LED's. The weak little T-amps aren't a problem, but I would like to apply this wonderful limiter to other amplifiers.
Post 1 lists the capacitor arrangement. Whatever noise that causes is entirely on purpose since it is better than clipping and acceptable since the device is off when clipping is absent.
The signaling is on purpose and highly desirable even though it is tardy. The 22uF cap swamps the timing error enough for clean voice and treble.
The extent (input voltage divider) was constrained until transparent; however, limiters that work better can be set to ride deeper and thus more effective without causing noise. There's always room for improvement, but making the limiter better also makes it progressively more difficult to improve.
Thank you for the input. I would greatly appreciate your help in protecting the LED's so as to be able to use ClipNipper with hundred watt amplifiers and not harm the LED's. For a hundred watt amplifier, we'd add a few more LED's for successful transparent engagement point, and then consider adding a zener to the chain.
Limiters make clean treble (because timer cap slows it down to avoid hashing the treble) but there will be "crunchy" bass when the amp is run well beyond max. That is correct for high efficiency limiter, since cutting that effect directly cuts the amplifier power (and we don't cut power output of 10 watt to 8R amplifiers).
Soft clippers run as fast as possible and make clean bass, but not clean treble, since they're not quite fast enough for treble. Can you make one go faster or fast enough?
I would love to have a working high speed soft clipper to clean the bass and use it in combination with my very nice limiter. I think that most of your post applies to soft clipper.
These two different circuits can be run together makes for clean audio band from bass to treble despite more decibels clean average output from the speaker. Compression occurs only instead of clipping, so compression does not occur when the amplifier is operated within its normal means. The trick is to keep the frequency response level, primarily have clean voice and treble (all that already done), and then try to provide loud clean bass.
I do have loud bass. But I don't have clean bass output well beyond the normal capacity of the amplifier. To do that needs a high speed soft clipper added.
Old 6th May 2012, 04:49 AM   #29
Do you have an example schematic handy?
Old 6th May 2012, 10:10 AM   #30
keantoken's Avatar
Those LDR's aren't too slow, 250uS will still pass 1KHz. I think you should still listen to it with a high-order LP filter just to see. Take a few diodes out so it's operating constantly and tune it. The better LP filter allows you to raise the limit corner frequency without applying more limiting to higher frequencies. Thus you get less crunch, but better effective speed.
My experience is with bad amplifiers (I point no fingers here), bass quality may not be evidently important because you cannot imagine what the improvement would be. But with better amplifiers, where you get a spatial sense of the deep mid-bass room reverberations, it becomes evident that there is something unexpected to having quality in frequencies below 1KHz. My experience is that periodic transients, such as from unsnubbed rectifiers, seems to ruin this spatial imaging. I theorize that the diode transients cause shifting operating points in the amplifier, or ground noise. An input limiter could be treated the same way. I suspect that like the rectifier, if the limiter has it's own form of glitching, whether from not enough filtering or from diode glitches, then several overloads in a second may be enough to disrupt imaging and decrease sound quality; this can happen with normal music. So I think you should at least try it and see.
I will get a schematic ready. The problem I see with enhancement FET protection is that there might not be FETs that can pass 10mA at a high voltage for too long.
LDR Limiter for TA2020, TA2024, spirited playback without clipping.Hide this!Advertise here!
Preamp: Comparing LDR and buffered LDR Dr.H Analog Line Level 19 15th February 2016 07:03 PM
Preamp / buffer suggestions for TA2020 / TA2024 boards lossfound Class D 11 29th January 2012 10:35 AM
VARDUS VR 300 and T-AMP? (TA2024/TA2020/TA2021B) Antigen Class D 0 30th March 2011 08:04 AM
TA2020 or TA2024? goodgnus Class D 27 17th February 2010 11:50 PM
The disadvantage of using LDR/Limiter circuits Dusk Solid State 2 21st January 2007 09:23 PM
