Sure Tk2050 4x100 really quiet - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th April 2012, 05:44 PM   #1
Default Sure Tk2050 4x100 really quiet
So i've just hooked up my first sure 4x100 and it sounds lovely, just doesn't seem to be able to go loud enough though?
Is there any jumpers or pots on this board hiding under the heatsink that will change that?
Tim
Old 9th April 2012, 04:32 AM   #2
This amp has no input buffer, so you'll have to use an active preamp to get decent level.
Old 9th April 2012, 04:37 AM   #3
Default Yup...
A common issue with most T-amps. Most of 'em are x15 gain vs x20 for many audio amps.
So a buffer with gain, or, another option is a 1:2 line-level step-up/isolation transformer. The problem is that a pair of good ones costs twice as much as the amp.
Commercial Site: www.HologramAcoustics.com
Old 9th April 2012, 12:32 PM   #4
I'm a little confused on this. The Sure site states the input sensitivity as 0.771 V. That is the required input voltage to drive it to full output and most home audio equipment should put that out. Is the issue the input impedance of 22 K? If driven by a device with a high output impedance the amps input could be loading that down too much so that the input voltage actually drops.What are you driving the amp with?
If the above is correct then the gain of the amp is not the issue, but the somewhat high input impedance. If that is the case then a buffer with very high output impedance might be required.
Rod
Old 9th April 2012, 08:17 PM   #5
It's being run off an M-audio audiophile USB from my pc. With the PC turned up to full and the m-audio turned up to full running some bose 4 ohm pc style speakers I'm getting a fairly normal listening volume, definitely by no means loud.
I asked sure the same question and their response was that I needed a 400w power supply, amazes me how clueless they are there, I'm definitely getting NO WHERE near 100w a channel out of it, my old 20wpc @ 4 ohm went much much louder.
Can't find the output impedance of the m-audio anywhere
Old 9th April 2012, 10:04 PM   #6
Rod
I misspoke - Should have said "If the above is correct then the gain of the amp is not the issue, but the somewhat LOW input impedance. If that is the case then a buffer with very LOW output impedance might be required.
Rod
Old 9th April 2012, 11:35 PM   #7
sofaspud's Avatar
What is the power supply you're using, by the way?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 10th April 2012, 07:17 PM   #8
using a 350w 24v PSU, so should be plenty of juice on tap.
Old 11th April 2012, 09:56 AM   #9
Problem solved!
Whilst I was watching TV last night through the amp it suddenly got much much louder?!!
Operating temps are the same, nothing was changed it just suddenly burst into life :lol:
Thanks for the help though guys.
Old 15th December 2015, 05:46 AM   #10
oculi is offline oculi  Australia
quick bump to this as I don't want to start another thread.
My version isn't a shure, is an ebay thing claiming to use a TK2050 but it isn't as loud as it should be.
setup is a 12 volt battery going to a voltage booster outputting 30 volts
the odd thing is I can turn it up to full volume (on the MP3 player putting sound into it) and adjust the input voltage from 12 to 30 volts and there is no discernible change in volume, wtf? might try burning it in for a while.
Sure TK2050 4x100 PLLXO & volume? Madumi Class D 1 25th November 2011 04:41 AM
Sure 4x100 as 2.1 setup tacobeast Class D 1 23rd April 2011 04:04 PM
Sure 4x100 as 2.1 setup tacobeast Class D 3 23rd April 2011 04:03 PM
How quiet is dead quiet? pchw Tubes / Valves 36 22nd November 2007 04:36 AM
Help: Aletc AC7300 4x100 amp StRaNgEdAyS Car Audio 2 12th August 2007 09:36 PM
Copyright 1999-2017 diyAudio
