Go Back   Home > Forums > Amplifiers > Class D
Old 7th April 2012, 06:14 PM   #31
please i don't know anything about mechanical engineering but I would like to build a car like those one Accueil - site officiel Maserati France can you help me?
Seriously as said by pacific blue you need to study first, because yet it seems you have no clue how to do anything!
I am currently thinking about building a class D amp by myself inspired by some international rectifier provided design + a FPGA for signal processing (as I know best FPGA than DSP or µC) but for those who believe is not possible to make an amplifier without DAC and think it is only marketing ******** they just don't know that class D is all about converting digital signal to analog without DAC but using PWM modulation.
Old 8th April 2012, 11:41 AM   #32
Originally Posted by sofus79 View Post
so i dont know if i just should buy his harmony server 2 or make somthing my self
The answer depends on your personal intension.
a) Do you want to have such a system?
b) Do you want to build such a system?
c) Are you passionate to learn how to design such a system?
Answers:
a) Just buy it.
b) Buy five of it, build one copy. Or check with core audio for a KIT.
c) Stop working and spend 5-6 years on learning theory and practise of general electronics, digital signal processing and switch mode power systems + spend massive money on equipment and components.
Old 8th April 2012, 01:58 PM   #33
do you have any other suggestions i really want to make a pc amp thing for my speakers
The easiest way is to follow post #20. Buy a PC with the interfaces you need. Buy as many class D amps as you need and connect them to the PC.
Free software crossovers are available on the Net.
he says that its better then LYNGDORF Millennium Mk IV and that his harmony server has better power supply etc
Of course he does. He wants to sell that stuff for a lot of money.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 8th April 2012, 02:43 PM   #34
Speedskater's Avatar
This sub-forum is all about analog chip amplifiers, nothing digital here.
I just noticed that in my post #17, I was confused about what sub-forum this was.
Kevin
Old 8th April 2012, 03:30 PM   #35
sofus79 is offline sofus79  Denmark
alright i cant find the ti link can you send it again
i am early retired so time i have a lot of
and the parts please send a link and help me find the parts i need
sorry for bad spelling and thanks for all the help you can give
Old 8th April 2012, 05:09 PM   #36
You weren't. See post #28.
Old 9th April 2012, 03:02 PM   #37
That's a good starting point
Class D amps components with digital inputs are becoming available from multiple manufacturers.
At least Diodes (Zetex), TI and Infineon do have such.
In detail the appoaches differ pretty much. As far as I see the TI approach is to use a PWM processor that feeds their digital power amplifier stages.
Digital Input Class-D Power Audio Amplifier with DSP - Infineon Technologies
PWM Processor from Texas Instruments
http://www.google.de/url?sa=t&rct=j&...6DhBkoFuqv3PUg
To get components you will need a combination of checking with the manufacturers directly and/or distributors, shops.
An extremely large component portfolio can be found at
Electronic Components Distributor | DigiKey Corp. | US Home Page - if you are rich and don't mind extra charge for the customs fees + high shipping cost.
The design itself must come from yourself/friends and application notes, because only very few people here will have a working design on hand. And those who have, most likely won't release here now. May be in 5 years, when it has established as standard technology.
Most likely some digital natives here will support you, if you show your design and come up with detailed questions.
It might also be worth to search for amplifier modules with digital inputs and digital PWM processing that can handle the signals from sound streamers like the squeeze box or similar and digital outputs from CD players.
Old 9th April 2012, 03:14 PM   #38
thanks great links
Old 10th April 2012, 08:53 AM   #39
stupid quistion again if a motherboard has pwm can i then connect it direct too the amp because one said that i have convert pcm to pwm
Old 11th April 2012, 12:00 PM   #40
The easy way
buy the whole stack from Home | miniDSP. Now you have 2 or 4 channel direct digital emplification and 4 channel DSP crossover. Take a cheap nvidia ion based motherboard (mediacenter mobo) and a SSD disk and you are up and running.
That is kind of what I have except for the SSD.
For more power and a bit more complex, look at TI evm boards like this
TAS5631DKD2 Evaluation Module - TAS5631DKD2EVM - TI Tool Folder
Or a readymade product, just add a PC
Wholesale DSP+CLASS D AMP+SMPS 2.1 OR THREE WAY HI FI AMP WITH ANALOG/SPDIF/USB SOURCE SELECTOR
PCM5102, 2VRMS ground centered direct output with two digital filters Eric Juaneda Digital Line Level 79 14th May 2013 05:46 PM
Want to build an active direct injection box (D.I) cosmox Instruments and Amps 25 23rd March 2012 10:54 PM
Direct 'Measurement' of AU-Based Digital XO vdB Multi-Way 2 14th October 2011 05:18 AM
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 04:43 PM
Direct Digital Synthesis oscillator Circlotron Digital Source 4 30th January 2004 12:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
