paralleling PAM8403 two channels
Old 30th March 2012, 11:22 AM   #1
J.Hoyer is offline J.Hoyer  Estonia
J.Hoyer's Avatar
Default paralleling PAM8403 two channels
I am building a "ghettoblaster" that is a single fullrange driver system. I have got PAM8403 (datasheet) 3W stereo amplifier board, circuit follows datasheet design.
Here's my question: can I parallel those two amplifier channels? If possible, would there be any advantage doing so, e.g. lower damping factor, more powerful bass?
Old 30th March 2012, 12:20 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Normally, I donīt suggest to parallel devices. As with transformers, or batteries wired parallel, always there exists a current circulating inside the device, that is wasted from supply and doesnīt go to load. Imagine the following situation: amplifier A gets input at a specific moment, a 10mV input. the amplifier amplifies it 100 times, output goes to 1000mV. The same signal goes to amplifier B wired parallel to amp a, but by manufacturing tolerances, it has 101 times gain, then the output goes to 1010mV, 10 mv plus that A. Suppose an output impedance of, say, 1ohm each. Then, 10mV over 2 ohms (the impedance between the amp A and B), means 20mA wasted in heating both amplifiers, and from supply, but load doesnīt see. Add to it, thermal derivative, noises, input current and voltages offsets between them, the result is a very poor performance as I can see. And with unpredictable fatal failures.
Salu2.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 30th March 2012, 01:22 PM   #3
tomc12388 is offline tomc12388  United States
Based on this [website], please read these two documents which states very clearly:
1) [Doc #1] from Wikipedia
2) [Doc #2] from National Semiconductor
Old 30th March 2012, 01:39 PM   #4
Both explain graphically what I told in words. Donīt mention the possibility of oscillations between the, I forgot to say it.
Regards.
Old 30th March 2012, 07:00 PM   #5
J.Hoyer's Avatar
Thank you for your responses! Especially interesting was the article from www.teco-audio.com
My main concern was that PAM8403 is a class-D amplifier and therefore totally different from class-AB amplifiers. I guess it is even more complicated to bridge or parallel them.
Anyway, seems that one channel of PAM8403 is sufficient to drive a 4W 92db vintage fullrange speaker to decent sound levels without distortion. Power supply with 3 AA alkaline batteries or rechargeable batteries (3.6 to 4.5 V). I also added extra 220uf low ESR capacitor near the chip. The second channel of that stereo amp is going to stay quiet with its input tied to ground.
Amazing little chip. Only disadvantage is quite high audible hiss (also with input tied to ground) but in "ghettoblaster" it is not a problem. Some pictures soon!
Old 30th March 2012, 09:23 PM   #6
J.Hoyer's Avatar
Heres the 2 x 3W PAM8403 stereo amplifier hooked up:
Old 30th June 2013, 10:05 PM   #7
wildwheelie is offline wildwheelie
Hi I was also looking at getting this baby amp board to play with; I also want to make a portable speaker box for my ipod/smartphone. You mentioned there is a hiss? Does it get louder with higher volume? More picture would be fantastic!!!
Old 2nd October 2013, 10:18 AM   #8
amfarina is offline amfarina
Dears
PAM8403(H) has 2 amplifier stages inside. Each one is bridge type, in order to apply the maximum (rail to rail) voltage to the loudspeaker. So, if you tie together the amplifiers outputs thinking to double output power with the same loudspeaker, you are out of way. So doing you'll have double current capabilities only and you'll have to half loudspeaker impedance (I say 2ohm) in order to obtain more output power.
Anyway you'll have a problem: if the amplifier have different duty cycles (also slight) we'll have a current circulating between the outputs stages and this is evident measuring the current consumption without signal. This will increase power dissipation, lower the efficiency and potentially fail your device.
The only way you can follow if you want double the power and use one loudspeaker only: place a transformer with 2x 4ohm primary windings (having low match between) each ones individually wired to an amplifier output, obviously the secondary will be suited for the loudspeaker impedance.
Have you a nice day
Old 16th December 2013, 11:25 AM   #9
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
I have the same board here..and planning to build a small portable MP3/ FM radio, my question is abt a capacitor named C7 on the opposite side of PCB where the chip is located. is this a supply filter capacitor ?
SivanandBalan
Old 16th December 2013, 11:56 PM   #10
doctormord is offline doctormord  Germany
doctormord's Avatar
Yes.
paralleling PAM8403 two channelsHide this!Advertise here!
Can I run tweeters off front channels and woofers off the rear channels of a headunit codyd70 Car Audio 0 3rd October 2010 06:11 AM
Paralleling class d channels Tekko Class D 0 17th July 2010 07:08 AM
paralleling the pcm1794s Aiace Digital Line Level 2 5th April 2009 08:46 AM
Paralleling transformers??? dfdye Chip Amps 10 30th January 2006 05:26 PM
Paralleling Transformers metal Chip Amps 8 7th March 2004 09:48 AM
Copyright ©1999-2017 diyAudio
