Concerns over powering class D amp
Old 22nd March 2012, 11:10 AM   #1
mrdude is offline mrdude
Default Concerns over powering class D amp
Hello all, I have designed a class D amp based around the HIP4080A IC and I am a bit unsure about powering it. I want the DC voltage bus for the full bridge to be only 10V and ideally I want to power the IC from the same rail. I'm using IRF640 mosfets which fully turn on with a gate voltage of 10V so I presume this is alright? I'm having a job trying to confirm this from the datasheet/ app notes so could someone reassure me that this will work okay and nothing will break. The app notes state that it has the ability to operate from 10V DC busses for driving H-bridges but should the DC bus voltage be greater then the VCC for the chip?
cheers
Old 22nd March 2012, 02:17 PM   #2
Boscoe is offline Boscoe  United Kingdom
I really don't have experience with your problem but I would of thought some headroom would be a good idea.
Audio projects and more: gswdh.co.uk
Old 22nd March 2012, 04:36 PM   #3
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Why not to try a notebook supply, around 12V?. If you strictly need 10V, add 3 diodes in series (2.1V loss).
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 22nd March 2012, 09:20 PM   #4
Pafi is offline Pafi  Hungary
Originally Posted by mrdude View Post
... should the DC bus voltage be greater then the VCC for the chip?
No, it must be able to operate down to 0 V power rail.
Concerns over powering class D ampHide this!Advertise here!
Concerns in making a dual output headphone amp jtavrisov Headphone Systems 8 7th November 2011 07:45 PM
Modular guitar tube amp power supply - interface concerns moonbird Instruments and Amps 0 26th January 2010 08:24 PM
Under-powering D-class amp. wsmckenz Class D 2 6th January 2010 08:42 PM
Studiomaster 2000E power amp performance concerns pinyoro Solid State 35 25th September 2009 11:19 PM
Battery-Powering a Trent TA-10 & a Citypulse DA2.03e leto Power Supplies 7 5th September 2008 11:15 PM
