diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Help a newb wire L25D (http://www.diyaudio.com/forums/class-d/209188-help-newb-wire-l25d.html)
ZachAttack420 19th March 2012 08:33 PM
Ebay wont allow me to forward email adress?
Can anyone help me identify which wires go where on the ljm l25d?
activexp 20th March 2012 07:25 PM
Look here and scroll down:
Assembled L25D Stero Power Amplifier board IRS2092 IRFB4020PBF 250W 8ohm | eBay
ZachAttack420 20th March 2012 09:34 PM
I am using a smps. Do I connect the negative terminal to the V- post of the power supply?
cwier60 21st March 2012 02:34 AM
Your SMPS must be a dual supply; e.g., +/-V. You can't just connect a single supply from +V to -V.
ZachAttack420 21st March 2012 05:44 AM
I meant negative terminal from the speaker to power supply? Or amp board?
I am using a sms800r from connexelectronic.
platenspeler 21st March 2012 02:49 PM
I built one with L20d and the SMPS800r of Connexelectronic.
Please look at this picture: <** Click this Link for Large picture **>
  • The -out terminal of the SMPS needs to be connected to the V- terminal at the amp board (yellow wire)
  • The ground terminal at the SMPS (o Vdc, black wire) is connected to the terminal on the amp board together with the GND speaker out.
  • the +out terminal of the SMPS need to be connected to the +Vdc terminal at the amp board (see red wire)
  • The thick Blue and Red wires at the amp board are connected to the speaker terminals
You do have to have the right version of the SMPS800r, 60-70 Vdc dual supply.
From your questions I get the impression you have no idea what you are doing, how to connect power supplies or how to interpret schematics (excuse me if I'm wrong). And although this amp is not so difficult to put together - it's connecting wires and not much more - this is certainly not a NEWB project. +/- 60VDc is killing.
Maarten
http://static.diyaudio.com/forums/ga...mbs/fini_4.jpg http://static.diyaudio.com/forums/ga...mbs/fini_5.jpg http://static.diyaudio.com/forums/ga...mbs/fini_6.jpg
cwier60 21st March 2012 03:54 PM
Contrary to the diagram on the eBay page that activexp linked to, the negative terminal from the speaker should connect to the amp board, and NOT to the power supply, as platenspeler described and hopefully his picture clarifies. Otherwise, the output load current would be flowing through the wires from the supplies, increasing losses and loop area.
platenspeler 21st March 2012 05:35 PM
I thought that's what I said ... but indeed speaker ground and amp ground connect together to amp board.
Maarten
ZachAttack420 21st March 2012 05:45 PM
Thank you. That is what I needed to know. Not a complete newb, but I preffer to ask than take a chance. Will be careful as always.
platenspeler 21st March 2012 06:01 PM
Maarten
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
