Forward error correction of PWM amps
Old 4th April 2012, 05:40 AM   #11
JZatopa is offline JZatopa  United States
Any updates on this?
Knowledge is Power & Applied Knowledge is Freedom,
There is no higher religion than truth
Old 4th April 2012, 05:45 AM   #12
phase_accurate is offline phase_accurate
I wonder how much success they will have - apart from the hype in magazines.
Charles
Old 4th April 2012, 07:23 PM   #13
ChocoHolic is offline ChocoHolic  Germany
Originally Posted by hahfran View Post
Available PWM full bridge amps are dirt cheap DIY makes no sense.
There are 2 channel amps 250 W output per channel , 500 kHz sampling, and switching power supply for less than 150 UK pound available.
Is money the key criteria for DIY?
First quantization error. At very low input noise causes quantization error and this appears as distortion in frequency domain. Sounds like crossover distortion but far more nasty.
I disagree on mixing up noise with quantization.
Analogue PWM modulators allow any duty cycle without quantization.
Their noise mechanism is depending massively on the jitter mechanisms of the used comparator. For sure a very different animal vs resistor noise, but not identical to quantization (predefined discrete values).
I'll give details once I have received their brochure.
If interested in relevant and correct information - better go for a beer with the design engineer.
Most likely the brochure is just there in order to manipulate your emotions and spend 10k money.
Forward error correction of PWM ampsHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
Re: New error correction amp mefistofelez Solid State 12 7th October 2010 06:55 AM
Error forward correction for Class D hahfran Class D 9 31st December 2008 07:16 AM
Error Correction Idea lumanauw Solid State 62 13th March 2007 01:59 AM
Will this work as Error Correction? lumanauw Solid State 4 8th October 2004 10:52 AM
