Go Back   Home > Forums > Amplifiers > Class D
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 3rd September 2004, 05:29 AM   #21
The most common misconception is that people are believing that the response to a pulse can't immediately be seen at the output of a filter. And this is WRONG.
If it really were like that, mankind wouldn't have flown to the moon, there were no modern aircraft with autopilot and much less of electronic assistance in cars etc etc
Charles
Old 3rd September 2004, 07:33 AM   #22
Originally posted by mikeks
...how do you class-d folks measure loop gain in your systems?
It's quite pointless to measure loop gain. Due to the sampled nature of a class D amp, you design for an exactly known and desired loop gain.
First you calculate what loop gain characteristic you want. Then you design the loop filter to do precisely that. Then you build your amp. If the closed-loop gain, THD and/or output impedance aren't what you expected, you've done something wrong. Conversely, if the measurements do match the calculations, loop gain is certain to match the design within a fraction of a dB.
Old 3rd September 2004, 07:48 AM   #23
Maybe it is the gain of the modulator/switching stage combination that Mike is curious about.
For the classic PWM amp it is simply the ratio of output_supply_voltage/peak_voltage_of_triangular_reference for instance.
Charles
Old 3rd September 2004, 08:03 AM   #24
If the rule is generalised to use dV/dt (at the comparator inputs) and switching frequency instead of pp amplitude of a triangle wave, it goes for non-classic-PWM amps as well. Again it's not something you measure. Mathematical truths don't need physical verification.
Old 3rd September 2004, 06:31 PM   #25
mikeks is offline mikeks
Account Disabled
Assuming your closed loop class d system takes an analog input, and outputs a nominal analog signal, then surely the applied feedback is necesarily voltage (shunt) derived, voltage (series) applied (AKA 'voltage' feedback).
Why would you consider it pointless to measure loop gain in such a system...?
One would have thought that in view of the significant phase shifts introduced by the output filter, (for feedback sampled after the filter), judicious measurement, or at least SPICE simulation of the loop transmission path would allow one to compensate for the filter's poles with precisely placed zero's in the loop..
...This should allow feedback to be maximized without compromising stability....
Old 3rd September 2004, 07:07 PM   #26
The output filter is an integral part of this mathematical study, as it is an integral part of loop gain. It is surprising that apparently you were assuming I forgot about this.
Poles in the filter become zeros in the error transfer function as a matter of fact!
Ergo:no such thing as explicitly compensating poles by zeros need be done. If it were, it would be impossible to do, as merely changing the load would obliterate the compensation scheme. So, we must thank mathematics for the fact that it happens automatically.
Class D amplifiers with correctly designed loops are extremely insensitive to changes in load or filter values.
I would like to invite you to perform simulations to see this for yourself. You will also appreciate the fact that to try and find the correct transfer function, by measuring actual hardware or even by simulating it, is a hopeless endeavour. The reason why so relatively few amplifiers with good post-filter feedback are made, is precisely because designers are afraid of doing the analysis first.
You will understand therefore that the phrase "to compensate for the filter's poles with precisely placed zero's in the loop" suggests you yourself are rather new to the subject of class D loop control. This is not a problem - I welcome anyone willing to become acquainted with the subject - but to try and teach me (or charles) how to roll a control loop while obviously being unexperienced at it oneself is not expedient to a fruitful exchange.
I hope you will understand my mild irritation and rest assured that no offense is meant.
Old 3rd September 2004, 07:41 PM   #27
Account Disabled
Actually, a working analog/digital class-d design was the subject of my dissertation many years ago....(scored 80% overall by the way...which was the highest mark attained on that course for such since it's inception)....
This included an indepth quantitative analysis of control loop (DSP and analog) schemes......including practical verification.....
Indeed, placing singularities in the feedback path to ameliorate those generated by the filter in the foward path has been quantitatively and practically demonstrated in JAES....I just cannot remember the author of the article at the moment....
Old 3rd September 2004, 08:13 PM   #28
Indeed, the degree of complication people are willing to go through while missing the obvious is a constant feature of class D design. Especially published papers tend to bear this out.
Old 3rd September 2004, 08:23 PM   #29
Account Disabled
Hi Bruno,
A simple low THD design would of course be interesting....
Complexity versus relatively poor linearity is the most discouraging facet of full-range class-d arrangements...
Simpler concoctions may be implemented for sub-woofer applications of course....
In respect of audio power amplifiers, i am a linear class-B/AB person really, but would be interested in your class-d design philosophy....and the sort of linearity obtained by its implementation...
Old 3rd September 2004, 08:41 PM   #30
Have a look around the threads that bear the word "UcD" in their title and check out www.hypex.nl who sell modules based on the concept. A spec sheet with plots is available there and will show the smoothest and most load-invariant frequency response you'll have ever seen since long. Effective output impedance is 20mohm+500nH, significantly lower than that of the boucherot networks typically found on linear amps.
Lower THD figures (-110dB) are readily realised, but so far the improvement on sound quality produced by this has proved zip (not a surprise considering loudspeaker distortion), so for the time being there are no plans offer these "improved" modules commercially.
Bruno
Thread Tools
Exicon 10n16 / 10p16 vs Magnatec BUZ900/905 hihopes Solid State 4 29th September 2007 09:59 AM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Magnatec Spec MNT-LC32020-C4 Mermprin Solid State 0 28th June 2004 09:15 PM
Magnatec FET's and their negative tempco Petter Parts 3 1st December 2002 02:43 PM
Page generated in 0.13712597 seconds (85.75% PHP - 14.25% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
