diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Adding "home style" I/O to a "Pro" Amp (http://www.diyaudio.com/forums/class-d/208624-adding-home-style-i-o-pro-amp.html)
Soldermizer 12th March 2012 03:00 AM
I am the happy owner of a Behringer NU3000 amp. You know, the guy who didn't like the fan noise so just took the entire fan out of the amp. :rolleyes:
This thread proposes a more reasonable (?) idea, applicable to most types of equipment. As you may know, the NU3000 is a "pro audio" unit which means it has weird input and output choices that confuse and frighten an old man who has only known home audio up until now. :yikes:
How much trouble, then, would it be to put in "normal" RCA female jacks and "normal" speaker binding posts instead of the Neutrik twist-locks? Is cutting metal required? Special tools? Maybe I should just buy (or make) adaptors, also it doesn't wreck resale value :smash:
noah katz 12th March 2012 03:57 AM
Radio Shack has adapters for converting inputs to RCA's.
Dunno about outputs, but what's wrong with Neutriks?
Soldermizer 13th March 2012 03:17 AM
Nothing I guess, I am just used to screw-on or whatever you call them for bare wire speaker connects (in recent years I learned the "tweak" of tinning the leads. Obi-wan (the Resale Force) says "buy the adaptors, Luke!" rather than Soldermize TM an otherwise perfect unit. Just askin'.
Copyright ©1999-2013 diyAudio
