| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
Have you compared any IRS2092 amps with those?
----------------------------------------- Noah |
#12 |
Even the Nu-Force have had varying reviews.
Class D amps can be susceptible to different loads, therefore one amp could sound good with one speaker and not so good with another. |
#13 |
agree with you. add that there's the subjective part, (or back ground of the listener). I think that an amp. independent of the speaker type, must have some performances at the base. as: good sn / r low hysteresis high resolution in high band low feedback level and not high DF. I am sure this may be debatable, but this is my philosophy and I use when I design an amp. Regards |
#14 | |
What does "single ended" mean in a class AB amp?? |
#15 |
I would interpret as not bridged into mono.
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is. |
#16 | |
) . Forget it because of your 2,6 homs, but interesting for the price about 140 euros with power supply. It has a remote control, you can play with 14 curves which make easy the synergie in your room and you save bucks and headeache with the dac question because it is a s/pdif input. Maybe i would try it in regard to the affordable view of your question.But in the same time, in regards to that which interest everybody of us (sound quality first DIY after ????? , can't know where i situate money here... between the two???? ) , maybe you can try one more powerfull (4 homs) little module of hifymediy if the money is the first issue to test class D. You can think too about 3 active stages for your speaker in the the view of improve the sound if you can go easily with active filter (but money!!! ) and in between I will go myself to the LME module because with 3 different speakers and many sources i found the sound of the DDX good but without life which is non acceptable (you can dream of Grace Kelly but you better live with Monica Bellucci to illustrate)...The more difficult for me is to think audio project in a money-time perspective... that's why i answer regarding your speaker first, the money question in second and class D quality question far after... You understand well it's non sense to buy Ncore for BW 610 speaker but in a perspective to change the speakers after... which I think about seriously in relation to my tastes. And because the room and WAF is the more difficult to change after 25 years of audio I ask myself of a total project : source (flac reccording, in this moment with synology and squeezebox duet) , active filter, amp (i consider Ncore but...) and DIY OB plan with B&G panels. It is very hard even in DIY audio to think global... i ask recently a too simple question about i/v stage's DAC : discrete/opamp/lamp in a versus perpective for best quality sound... no responses : schools before sound .But sory for my too long answer and bad english, I hope it helps in regard to my experience. |
#17 | |
which chip do they use in the SDA-400 ? I heard about break issue with the NuForce integrated amp... I 'm myself very curious about make a AB/BA test (dancing qween) between NCore and Nuforce. But Ncore if you read DIYaudio seems to be a good bargain for High End... even famous brand want to include it in theirs commercial products. All seems to go with redesign of input stage (to make the sound different cause Bruno P. seems to be a clever guy who design neutral in relation to the music! ....which speakers does he use will be interesting to know) and linear power supply (to make heavy à la ancienne façon ??? = easier to sell for many bucks if the box is in massive aluminium and the total weight > 20 kg = XX° century like, I mean: in consumer perspective).
| New-Class-A ? (whats it mean) | Rixsta | Solid State | 33 | 28th September 2011 03:24 PM |
| Whats the best budget T Amp? | Bill poster | Class D | 7 | 10th August 2011 04:13 PM |
| whats makes sense to have class A amp? | space2000 | Solid State | 64 | 7th July 2008 03:46 PM |
| Amp Turns on and off whats wrong?? | db junkie | Class D | 2 | 26th October 2005 12:09 PM |
