Just for fun: UcD on a shoestring - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 25th February 2012, 04:40 PM   #1
Elvee is offline Elvee  Belgium
Elvee's Avatar
Default Just for fun: UcD on a shoestring
Here is a truly minimalist amplifier: a total of 4 transistors, and it actually works, it has been built.
I think it would be difficult to make even simpler without seriously compromising something.
Have fun!!!
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 25th February 2012, 05:53 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Brilliant. This renders all other previous ZEN work (and thinking) obsolete.
btw: I think you mislabeled IRF9530 as IRFP530.
I use to feel like the small child in The Emperor's New Clothes tale
Old 25th February 2012, 06:12 PM   #3
Elvee's Avatar
Sorry about that: as there was no IRF9530 in the native library, I simply changed the sex of a IRF530 as a quick fix.
The transistor I used in my prototype was in fact a IRF9630, and I forgot to edit the name after the sim was completed.
Old 25th February 2012, 06:16 PM   #4
theAnonymous1's Avatar
I know you did this for fun, but how well does it work?
This is simple enough for even me to build; not that I understand how it functions in the least. Have the parts to do it though, so why not.
Old 25th February 2012, 07:10 PM   #5
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
I got to say, this one will be hard not to just try and see, just for the fun of it
did you try it on any other voltages too, I got few supply, that have a bit higher voltage
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 25th February 2012, 08:01 PM   #6
Elvee's Avatar
Difficult to tell: other than a dummy load, I tested it on an unboxed 4" speaker.
In those conditions, it sounded normal....
No I didn't. I tested it on a regulated supply, and with unregulated supplies there would probably be ripple rejection issues.
It could probably tolerate somewhat higher supplies, but at some point, the gate voltage might become excessive, as this is not controlled in any way.
Up to +/-20V should be safe, but be careful...
Old 25th February 2012, 08:04 PM   #7
elevator's Avatar
Very cool!
Question: how do you change the sex of an IRF530?
(I mean in LTspice)
-E
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 25th February 2012, 08:31 PM   #8
stewin is offline stewin  Kenya
nice one elvee. do the outputs heat at 2 ohms playing hard?
Old 25th February 2012, 08:52 PM   #9
Elvee's Avatar
Originally Posted by elevator View Post
Very cool!
(I mean in LTspice)
-E
Want to try on yourself? Naughty boy!
Open the standard.mos library with a text editor, copy and paste the line of the victim transistor, and edit "nchan" into "pchan", and also edit the component name in recognizable way; when I do this kind of "operation", I add a P or a N somewhere, and I take care not to duplicate any real component.
When it's done, it looks like this:
.model IRFP530 VDMOS(pchan Rg=3 Vto=-4 Rd=50m Rs=12m Rb=60m Kp=5 lambda=.01 Cgdmax=1n Cgdmin=.26n Cgs=.2n Cjo=.4n Is=52p mfg=International_Rectifier Vds=100 Ron=160m Qg=26n)
which is an ideal complement for the IRF530.
Not very realistic in real life, at least for MOS transistors. For BJT's, it is less of an issue, you can find real components that are almost an ideal match.
I tried only on 8Ω, full power (12V supplies) and the transistors remained cool.
Only the 18µH coil was hot, but it was an ordinary iron powder (white yellow) toroid, not quite suited to the ~200KHz switching frequency
Old 25th February 2012, 09:30 PM   #10
elevator's Avatar
Actually I've already tried the sim with other complementary pairs, and it works nicely. So I just wanted to reproduce your original.
Thanks much for the directions, cheers
-E
Edit: I believe the P version should also have Vds changed to -100
UcD 180 or UcD 400 with +/- 48VDC supply Ray Weikel Class D 17 7th March 2009 06:11 AM
OB on a shoestring? merajsalek Multi-Way 4 9th February 2009 01:13 AM
Bride of Zen on a shoestring Peter Daniel Pass Labs 39 16th April 2004 07:35 PM
Gainclone on a shoestring Paulr Chip Amps 1 25th April 2003 05:40 PM
Copyright ©1999-2017 diyAudio
