UcD project, Subwoofer class d amp, full h-bridge, single supply +50 V - Page 5 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 6th March 2012, 09:37 PM   #41
lorylaci's Avatar
Send a message via MSN to lorylaci
Originally Posted by norazmi View Post
ok then, i will use IRF540N for testing, now i need to search for HIP ics. If its success i`ll use IRFB4710 its good enough i think
IRFB4710 has very high gate charge (even the HIP4080A'a 2,5A is not enough for that), and a very bad diode. Look at IRF540Z datasheet, it has a 62nC max diode, pretty good (and 63nC gate charge).
Bad diode not only means losses, but will give you high EMI, which will cause noise and distortion also.
Check Intersil's website first. Then check the distributors for your country. HIP4080A is not so expensive (its cheaper than an IRS2092).
Olyan nem volt még, hogy ne lett volna valahogy
Old 6th March 2012, 10:07 PM   #42
norazmi is offline norazmi  Malaysia
got it, im order directly from intersil and request sample too.
Old 7th March 2012, 11:57 AM   #43
lorylaci's Avatar
If you order samples from Intersil (I did too), don't order too much things, otherwise you will have to pay customes (usually up to 5 pieces of ICs it is below customs value)
(there was one ocassion when I had to pay customs )
Old 7th March 2012, 02:09 PM   #44
i just order 10 pcs and + 2 samples, here in my country tax will be charge if order more total amount more than $200 usd. I think i`ll passed it
Old 7th March 2012, 02:29 PM   #45
emilvv is offline emilvv  Bulgaria
Default Hello ..
Hello,
I have a new question about HIP4081 ...
As lorylaci suggested here: ....
Can you tell me how max output power can be released from: ...
Single supply bridge UcD, referencing the signals
see .... 400w single supply btl ucd.pdf ..
and how much will be THD+N with 56 V DC and 8 ohm load ( and 4 ohm load to ... ) ??
lorylaci says : ... "Because IR2110 has limited pulse width" ... so is the HIP4081 better ???
Also .... "But using HIP4080 with integarated high-speed comparator can raise your modulation limit" .... so ... using HIP4081 + external TL3016 is better than combination of LT1016 and 2 x IR2110 ??
All answers are for subwoofer amp ... 0-300 Hz ... 8/4 ohm load ..
Emil
Old 9th March 2012, 08:16 PM   #46
lorylaci's Avatar
Originally Posted by emilvv View Post
Hello,
Emil
Emil, please take the pain to read the datasheets, and don't ask what is obvious. HIP408x has a maximal supply limit of 80V, sok you can calculate the max output power to all loads from that.
HIP408x has better gate driving, dead time setting ability, and no minimal pulse width error (or at least I haven't head about it). Using HIP4080 is better than HIP4081+external comparator. Using HIP4081 with comparator, is shure better than using IR2110s. IR2110 has much higher prop delay.
CroMagnoic did not state any THD+N measuremns, so I cannot say that either. Why don't you ask him? But this model with good dead-time adjustment is propapbly capable of THD+N < 0,1%.
Old 15th March 2012, 05:18 PM   #47
Lorylaci, i`ve receive Hip ics, BUT its soic package , damn, i`m dead with soic arghhhh....
Old 13th December 2015, 12:37 PM   #48
Default Schematic is different from pcb
Hi lorylaci,
I found the C2 connect C16,C17 on the schematic, but the C2 connect C14 and C15 on the PCB. Which is correct? thanks!
Single supply bridge UcD, referencing the signals Cro maniac Class D 89 4th August 2016 06:20 AM
UCD Based Fully Differential Full Bridge 450W RMS Amp classd4sure Class D 90 27th August 2012 08:48 PM
full bridge selfosc class d amp Tekko Class D 21 12th May 2011 08:00 PM
Full bridge UcD Help, not work witali Class D 2 24th March 2006 02:34 PM
Copyright ©1999-2017 diyAudio
