clueless novice in need of advice
Old 19th February 2012, 04:13 PM   #1
mrdude is offline mrdude
Default clueless novice in need of advice
Hello I am attempting to design a discrete class D amp as part of a project and as the title of thread suggests I don't really know what I'm doing. Unlike most of the posters here I am not concerned with brilliant efficiency or high fidelity just a functioning amplifier. It would be greatly appreciated if anyone could give me a little guidance and hopefully some re-assurance I'm going in the right direction. Currently I'm trying to work out the output stage which is a full bridge design as shown below.
*the load is an 8ohm speaker
If I have a PWM signal at 250 kHz alternating between +/- 5V what would be the best way to drive the MOSFET's? I know from what I've read that using N-channel MOSFET's for both the high and low side gives better results but the additional circuitry for level shifting seems a bit beyond me.
Old 20th February 2012, 12:59 AM   #2
elevator is offline elevator  United States
elevator's Avatar
MrDude,
Zetex used to have an eval board for their driver chip, using complementary pairs in a full bridge arrangement like you want.
Try locating zxcd50steval.pdf.
Blank out all the protection circuitry and notice how the pairs are driven via two caps from a 12V PWM signal.
E
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 20th February 2012, 01:40 AM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
One way of doing it using a triangle wave generator and audio signal going into a comparator. The output is then level shifted into a phase splitter for the two pwm signals.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 20th February 2012, 02:10 AM   #4
Use IR2113 to drive N channel FETs
Old 20th February 2012, 03:29 AM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Your concept schematic is only suitable for high supply voltages because it works as a power "voltage follower".
Swap N-ch and P-ch, and D and S connections, and analyze the resulting circuit.
I use to feel like the small child in The Emperor's New Clothes tale
Old 23rd February 2012, 11:05 AM   #6
Thanks for the replies, I had a look at the data sheet for the mosfet driver Nigel suggested and though I can't be sure I think maybe using just n-channel mosfets may be easier. I drew out a little diagram to try and get my head around what the driver actually did and how I could use it. Hopefully my understanding isn't too flawed.
Thats for a half bridge, I don't know how a full bridge would be connected. I'm guessing you have a second driver but with the low and high outputs connections reversed or something. Also I couldn't see anything about it on the datasheet but does it have ample dead time? I noticed that this driver can handle very high voltages, I take it that it works fine with 5V or does it need a higher supply voltage? What sort of n-channel mosfets should be used with these drivers? Sorry I'm asking so many things but these things don't seem to mentioned on the datasheet.
Old 23rd February 2012, 11:46 AM   #7
marce is offline marce  United Kingdom
The easiest way to get into class D is find a reference design for your controller of choice and copy it. It will help you get to grips with the complexities and generally give you a layout to follow, as class D and SMPS's require the correct layout to functio and not pollute the world with EMI noise.
Old 25th February 2012, 08:13 PM   #8
elevator's Avatar
mrdude,
you may want to check out this thread on a simple design using a complementary pair:
http://www.diyaudio.com/forums/class...hoestring.html
-E
clueless novice in need of adviceHide this!Advertise here!
Novice needs advice: building a suitcase amp Exfish Instruments and Amps 8 30th September 2011 04:28 AM
Clueless.. Newbie33 Introductions 3 24th November 2008 10:05 PM
clueless needs help Vista Multi-Way 2 22nd February 2003 08:40 AM
Advice for Novice Little_Eddy Solid State 0 3rd January 2003 09:43 PM
Copyright ©1999-2017 diyAudio
