multichannel amp using irs2092 boot sync question - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th February 2012, 10:47 AM   #1
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
Default multichannel amp using irs2092 boot sync question
we found some type of multichannel amp using 2092, can these products realize two or more channel boot sync? if can not boot at same time when power on, we can hear one channel sound and the other delay.
any friends have good solution of this?
we have to design external osc fixed frequency class D in our 2way or 3way active module.
we have test 2092 evm board, boot different time,and EMI value not good as fixed frequency type.
Old 17th February 2012, 12:42 AM   #2
nigelwright7557's Avatar
The 2092 starts up if all the voltages are correct around it.
To make them start together you could add a small circuit to apply a reset signal to both amps for a couple of seconds until both are in the right state for power up.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 17th February 2012, 10:44 AM   #3
irs 2902 sd pin pull down when power on , then shift it,i don't know it is good choice or not, because self osc start at different time.
IRS2092 High Power mosfet heat question ungie Class D 40 11th December 2012 07:45 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 08:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 03:29 PM
Multichannel T-Amp starn02 Class D 9 7th May 2006 04:22 PM
Copyright 1999-2017 diyAudio
