HI,
I'm looking to run 2x 200W RMS speakers with a Connexectronic IRS2092 Modular Amplifier. The 600W Version. I also want to use one of these in line with the circuit aswell. Connexelectronic
What power supply would be recommended??
Jake
Jake
The SMPS Switch Mode supplys are what i was thinking of.
Jake
A transformer, bridge and smoothing caps is much easier to fix if it goes wrong.
An SMPS has a lot to go wrong.
That's a good point.
I don't so much mind the weight of linear as inefficiency, but I'm not clear on just what that is.
Any idea what idle and full power losses are with +/-60 V rails?
Average power is low, so I don't much care about the latter.
There is nothing inefficient about a linear supply.
A transformer is very efficient.
Its linear amplifiers that are inefficient. class AB is about 60% efficient whereas class d is 80%-90%
- Class D
- IRS2092 Class-D Amplifier
