low cost jitter measurement -117db - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 12th February 2012, 01:10 PM   #1
Default low cost jitter measurement -117db
This jitter measurement does focus on jitter on clocks and PWM signals of 200kHz-1MHz as widely used in class D amps.
The measurement does display the noise that is generated in the audio band by the jitter of a clock or PWM or level shifter or gate driver... .
Basically the circuit is a high order filter with 60db gain over the audio band.
A 400kHz carrier is suppressed by 118db.
The equivalent input noise is approx 5uVrms, which means a measurement limitation of -117db, when considering a +/-5V PWM signal.
When checking a 400kHz PWM in time domain this would demand measurement equipment with an accuracy better than +/- 2ps.
In real life I am using two NE5534 (compensated with 39pF) for the voltage followers. The gain stage is working fine with LT1037.
At each OP amp there is a 100nF ceramic between pos and neg supply - not shown in the schematic.
The GND wiring should follow the geometric sequence as visible in the schematic. Suppressing 400kHz with 118db demands a certain discipline
The -3db bandwidth is slightly above 17kHz, fitting well to simulation.
Old 12th February 2012, 01:50 PM   #2
Default first measurements
When the input is shorted we can find an output noise of approx 30mVpp.
Means 5mVrms, means an equivalent input noise of 5uVrms.
The second measurement is the noise of a standard signal generator delivering a 4.8Vpp rectangular with 400kHz. It has noise of approx 383uVrms in the audio band. Not fortunate as a source to generate a triangle! Assume we go for a +/-200mV triangle by a simple RC..., then the related RC will let pass the noise in the audio band in full. Means we have 383uVrms noise on the triangle. The triangle is being compared with an audio signal of +/-200mVpp... assume sinusodial.. means 141mVrms. 383uV noise on 141mV signal means -51db.
Even when considering that this poor value might be cured by the feedback loop, say the amp output might be 20db-30db better.. ..obviously it is making sense to spend some love on a low noise triangle for a clocked class D amp....
Old 12th February 2012, 03:25 PM   #3
elevator's Avatar
Originally Posted by ChocoHolic View Post
...spend some love on a low noise triangle for a clocked class D amp....
Choco,
this confirms a suspicion that I had for a while, namely that triangle generators seen in clocked designs are rather underwhelming for the most part. I just never got around to scratching my head on it and figure it out...
-E
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 12th February 2012, 03:59 PM   #4
While layouting my new class D, I came to the conclusion that I should have a look to this before routing the oscillator...
In fact up to now I am not convinced that a crystal with frequency divider is necessarily better than an analogue hysteresis oscillator.
Right now measured the 310kHz/4.8Vpp analogue hysteresis oscillator (with low noise rail supply and LT1711) that I used some years ago to clock my MosFet relay. Finding 18uVrms. This means in time domain a jitter below +/-17ps (rms weighted), max. values +/-51ps. I never digged into the crystal oscillators and frequency dividers, but I am not convinced that you easily get such low jitter after dividing down to few hundreds of kHz.
Real life experiences and measurements highly welcome.
Old 12th February 2012, 04:55 PM   #5
AP2 is offline AP2  Italy
Banned
Hi ChocoHolic,
You can show triangle wave on oscilloscope with right zoom possible?
regards
Old 12th February 2012, 07:33 PM   #6
Which zoom would be right from your view for a 400kHz triangle with +/-200mV?
Just let me know your desired time scale and voltage scale.
Old 12th February 2012, 08:33 PM   #7
...something like this?
Old 13th February 2012, 10:19 AM   #8
Banned
Thanks Choco, it is good to see the corner, I see that it is clean.
geometry also looks good, it is preferable to see at 400nS/Div.
have no doubt, which is much better oscillator with hysteresis for noise. a problem can be the amplitude of the triangular, is too low 200mV.
Old 25th February 2012, 07:02 PM   #9
Default Measurements
..and now - why I build this measurement tool.... Measurements !
Measurements on analog hysteresis oscillators:
All Oscillators operated in the frequency range 310kHz-700kHz.
Bandwidth of noise measurement: 17kHz
1) Hysteresis Oscillator build from LT1711:
Output signal: 4.8Vpp ==> equivalent PWM audio signal: 1.7Vrms
Output noise: 18uVrms
S/N ratio: 99.5 db
2) Hysteresis Oscillator build from LM360:
Output signal: 5.6Vpp ==> equivalent PWM audio signal: 1.98Vrms
Output noise: 17uVrms
S/N ratio: 101db
3) Traditional astable multivibrator build from two BC550C:
Output signal: 9Vpp ==> equivalent PWM audio signal: 3.19Vrms
Output noise: 5uVrms
S/N ratio: 116 db
Noise measurements on triangle PWM modulators:
Approx +/-270mV / 312kHz triangle was derived from the second oscillator above.
RC of 1k8 and 4n7 directly at the input of the following comparator.
This triangle was connected to a comparator input, while the second comparator would be fed by the audio signal. For the noise measurement the audio signal was zero (jumper to GND).
The measured noise on the triangle was 11uVrms ==> S/N ratio of triangle: 85db
Findings on LT1711
Output swing 9.6Vpp
Output noise: 7mVrms !!! ==> S/N ratio of PWM: 54db
It was found that the noise could be massively influenced by the wiring of rectangle.
Another massive impact was found by putting a probe at the triangle ==> 2 times worse.
Looks like LT1711 has an unpleasant mechanism to transform HF-noise into a LF-jitter in the audible frequency range.
Note, the LT1711 did not show panically output flipping, also no obvoius jitter on scope screen.
Findings on LM360
Output swing 4.2Vpp
Output noise: 78uVrms ==> S/N ratio of PWM: 85db
Old 4th September 2013, 09:40 PM   #10
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
These measurements are very interesting.
Markus, do you have spectrum data?
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 14th September 2010 12:39 AM
Jitter measurement jtkraj Digital Line Level 0 24th March 2009 01:47 PM
Jitter measurement pop11 Digital Line Level 8 26th January 2009 05:54 PM
Low space / Low cost B20 Trooper46 Full Range 5 13th September 2008 06:01 PM
Low jitter crystal bocka Parts 2 24th July 2003 10:53 AM
Copyright 1999-2017 diyAudio
