Go Back   Home > Forums > Amplifiers > Class D
Old 12th February 2012, 06:31 AM   #1
Default low wattage mono amps
This may seem like a stupid question, but.....
Are there any boards/kits/schematics out there for single channel amps in the 10-15 watt range?
I am engaged in an ongoing project to convert my entire library to FLAC, to stream wirelessly with AirPlay dierectly to each set-up. As a first step, I am interested in converting a set of speakers to an active configuration, with on-board amps, and am looking for a solution other than running two t-amps with one channel fed to each half of the board.
Any suggestions would be warmly welcomed.
Thanks,
Robert
Old 12th February 2012, 12:27 PM   #2
elevator's Avatar
Glad you asked
I'm just about ready to have PCBs fabbed for something in that field.
It uses the TI TAS5727 chip in PBTL, meaning
15W into 4Ohm @12V single supply
38W into 4Ohm @18V single supply
The TAS5727 has digital input (i2S), soft limiter and a programmable DSP, interesting for speaker cabinet equalization etc. See here: Speaker Amplifier and Modulator - Mid/High-Power Amplifier - TAS5727 - TI.com
The board is meant to be used for distributed audio systems.
At higher supply voltages it can even serve a subwoofer IMO.
Here is a PCB render. If you're interested, I can have a few more built.
-E
You don't need a weatherman to know which way the wind blows --Bob Dylan
anyone have any experiences with low wattage chip amps? AltecDarpa Chip Amps 8 22nd January 2012 04:18 PM
Low Wattage Multi Channel Amps? sumsound Solid State 0 21st December 2010 06:59 PM
low wattage valve amps Benjamin Craig Tubes / Valves 14 30th November 2010 11:17 PM
Does preamp wattage effect power amps wattage? JonnySwitchblade Solid State 7 4th July 2007 03:18 AM
Looking for a Low Wattage Amp Schematic. surf,sun&sound Solid State 15 24th December 2001 01:50 AM
Page generated in 0.07856 seconds (69.35% PHP - 30.65% MySQL) with 11 queries
