| Class D Switching Power Amplifiers and Power D/A conversion |
I just bought 4 T1's and 2 SMPS300R power supplies. 3 came as version 1.3 with the on/off switches, the fourth is version 1.2 and has no switch. I wired one of them up to test and wasn't getting any audio out. I turned it up a bit and noticed very faint music coming from the speakers. I went back to the amp and noticed that music was also coming out of the amp! I thought I was crazy and you may to but I swear, it was audible through the amp. I could tell what song was playing! What have I done wrong? I bought the version without the pot. Do I need to do something to the pads where the pot is supposed to be? Caps, resistor, jumper? I tested the voltage in and I'm right at 36v on the money. I also checked the a/c voltage at the speaker terminals. When the audio gets noticeable, it's about 10 volts.
#2 | ||
That song being reproduced by your speakers is comming from some radio station as If you leave the inputs open on your amp they will work like an antenna and so the signal captured then is amplified and by having a power amp you are playing that signal at max volume. That's why you can tell what is the song playing. Having a power amp, with random signal is not an good idea. Also don't connect or disconnect anything to your amp while it is ON, specially while it is not fully grounded yet. []'s Last edited by Virpz; 10th February 2012 at 04:16 AM. Reason: WWWWWWWWWWWhhhaaaaaaaat ????? Your amp ? |
#3 |
Yes, the sound was acutally coming from the amp. I know it sounds insame, but there were some harmonics resonating to the music in the amp. I wonder if the relays could do that? The source was coming from the zone 2 pre-amp output of my Onkyo receiver, not from a radio station. I had intended to use the volume controls on the Onkyo to control the volume. This is why I didn't get a pot.
Thanks edit: I figured out my issue. I had the amp wired to a speaker selector. I had one pair enabled and the "circuit protection" switch turned off so that it was basically straight through. However, I selected the wrong switch; one that wasn't connected to anything. I was driving the power into a open circuit, infinite resistance. So when I turned the pre-amp up high enough, somehow sound was bleeding onto the other speakers and through the speaker selector and something in the amp was acting as a speaker as crazy as it sounds. I turned on the correct pair, and it sounds good now. I can't turn it up too loud now though because it's getting late and the speakers are outside. I'll do some better testing tomorrow. Here are some pics of the stuff:
| What enclosures work for Hifimediy T1, T2, T3, T4? | skyler | Class D | 1 | 19th January 2012 12:38 PM |
| Hifimediy T1, T2 or both to drive NHT SB-3's | Sotirio | Class D | 0 | 30th May 2011 09:05 AM |
| FS: Tripath TK2050-Hifimediy T1 Module Alps | force of 1/2 | Swap Meet | 0 | 4th May 2011 01:51 AM |
| Help please with Teac VRDS-T1 | georgehifi | Digital Source | 0 | 14th February 2006 02:40 AM |
| Is the T1 worth buying? | pat99 | Subwoofers | 4 | 8th December 2005 12:47 PM |
| Page generated in 0.08531 seconds (72.71% PHP - 27.29% MySQL) with 10 queries |
