Go Back   Home > Forums > Amplifiers > Class D
Old 7th February 2012, 09:47 PM   #1
Default Arjen TA2020 Help needed
Hi! bought the ta2020 MkIII kit from arjen a while ago.
I wired it up yesterday and im sure that i did the correct wiring. But there is a problem.
The powersupply that was supplied with the kit, when started the led is flashing on the power supply. and a clicking sound from both speakers and the relays is appearing. Its like a pulse. The same is for the Power LED on the arjen Board and the Over LED. I have video of it if requested.
Please help me, im just a beginner
Old 7th February 2012, 10:01 PM   #2
Katch is offline Katch  United Kingdom
something is shorting/drawing too much current - it's the protection kicking in. Mine did it when I was messing around with different LEDs. Double check your wiring.
Post a nice clear photo of your build and I can check for obvious errors. Also look for my post a few pages back - it has a good wiring diagram drawn by Arjen.
Next thing to do is take things out of the equation - try just the board and the psu (disconnect the speakers and inputs)
Then add things back one at a time till you get the problem again.
Edit:
Here you are - this is how the input side should be wired
Old 7th February 2012, 10:06 PM   #3
Thanks! ill try it, im quite surtain that i did the input right, i have no channel selector so its simple.
Old 7th February 2012, 10:12 PM   #4
Thanks for the advice! found the problem, Took out my potentiometer and the voltage from the powersupply was like 1,5 volts.. so i adjusted it and it works perfectly!
Old 7th February 2012, 10:18 PM   #5
the short/problem will be on your 12v circuit somewhere.
does the PSU flash when it its plugged in on its own not connected to the amp?
Old 7th February 2012, 10:25 PM   #6
Its fixed now! haha the voltage was turned down to 1,5 volts on the smps so, now i turned it up to max and the smps led is no longer flashing, the Power led for the amp board is fluid and the OVER just flashes for a milisecond when starting (i hope that means ok) So no problems! thanks for the advice tho
Old 7th February 2012, 11:09 PM   #7
check the dc output with a multimeter if you know how just to make sure it's sitting nicely at 12v. The ta2020 can take a bit more voltage and I doubt that the PSU Arjen supplies could damage it but its best to check it.
Old 8th February 2012, 10:31 AM   #8
Well, it's sounds good at the moment. Yes, i doubt that he will supply the costumers with a fault smps
Arjen Helder tube pre on ta2020 and maybe a MINIDSP? JOHNNYFAMOUS Class D 21 17th May 2012 08:44 AM
Arjen Helder TA2020 build question Katch Class D 4 20th January 2012 02:22 PM
Arjen Helders TA2020 with horrible base line t04fr Class D 6 27th September 2010 12:14 PM
Arjen TA2020 MkIII kit wiring paean Class D 7 16th September 2010 04:11 PM
Does Arjen TA2020 accept 220v AC? Aurality Class D 7 14th September 2010 10:31 PM
Page generated in 0.20907 seconds (35.27% PHP - 64.73% MySQL) with 10 queries
