More output power at higher loads and less power at lower loads. How it is done ? More output power at higher loads and less power at lower loads. How it is done ? - diyAudio
Old 7th February 2012, 07:08 PM   #1
Virpz is offline Virpz
Exclamation More output power at higher loads and less power at lower loads. How it is done ?
Hello
I was looking out at some amps that perform best at higher loads.
For example:
Hifimediy T1.
- It provides 100W on 8 Ohms ( 39V 5A ? ) and 50W at 4 Ohms.
I want to know what is done in order to provide more voltage and current to the speakers because it seems to foul Ohms law ?
Forgive me if it has already discused here but I tried to search the awsner here and on the web without success.
Thank You
Old 7th February 2012, 07:14 PM   #2
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
It's current limited.
100W into 8 ohm = 40V and 2.5A
50W into 4 ohms = 20V and 2.5A
Old 7th February 2012, 10:00 PM   #3
Never tought of that. LOL
One may call this kind of technique just "market strategy" ?
[]'s
Old 8th February 2012, 06:29 AM   #4
Saturnus's Avatar
I'd call it honesty. If the output chip used is current limited then an honest manufacturer will note that it has lower output into 4 ohms instead of letting the buyer assume that it can output twice as much in as into 8 ohms.
Many amps are in fact current limited without the manufacturer noting it.
Old 8th February 2012, 03:07 PM   #5
Good point.
I must agree with your view.
[]'s
Old 8th February 2012, 05:07 PM   #6
Saturnus's Avatar
Btw, in the interest off being complete. It's current limited for the package. So if you for example used it in an active speaker with a 8 ohms tweeter and a 4 ohms woofer, the total current limit would still be 5A which would be
Woofer section ... 4 ohm ... 26.67V ... 88.9W
Tweeter section ... 8 ohm ... 26.67V ... 44.5W
That'd still keep you in the 5A limit.
Old 8th February 2012, 08:59 PM   #7
Pafi is offline Pafi  Hungary
I don't know what do mean.
26.67V/4ohm=6.65A
Old 8th February 2012, 09:33 PM   #8
Saturnus's Avatar
26.67V/4ohm=6.65A
Peak, yes. RMS, no. RMS is what matters in this case.
Old 9th February 2012, 06:23 PM   #9
Then write it down! Never mix RMS and peak without mentioning it!
Still fuzzy.
More output power at higher loads and less power at lower loads. How it is done ?Hide this!Advertise here!
Why i always have those losses in power using lower impedance loads? destroyer X Solid State 12 5th June 2007 03:49 PM
Speccing power transformer for several speaker loads privateer Chip Amps 6 22nd June 2005 01:38 PM
? HT speaker loads and amp power 2Bit Multi-Way 2 8th January 2004 10:49 PM
Dale Power Resistors 4 Sale. Great Loads for Testing Bill Fitzpatrick Swap Meet 0 6th June 2003 01:14 AM
Power output into small loads Wingfeather Solid State 9 6th April 2003 06:30 PM
Copyright ©1999-2017 diyAudio
