Go Back   Home > Forums > Amplifiers > Class D
Old 5th February 2012, 07:34 PM   #1
Default PWM to Analog conversion.
I'm building an amplifier with the TAS5518 processor.
I wish to use also the PWM output from it for the headphones.
Can somebody tell me how to convert the TAS5518 Differential PWM Output to analog to be used with a standard OpAmp?
Thank You very much.
Old 5th February 2012, 07:55 PM   #2
nigelwright7557's Avatar
Resistor and capacitor is simplest into non inverting input of op-amp.
IR2113 is another option.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 5th February 2012, 08:24 PM   #3
Pafi is offline Pafi  Hungary
Well... yes, a low pass filter can convert "PWM to analog", but for high quality DVDD and DVSS must be perfectly clean, wich is not automatically true!
NAD M51 DDDAC- Eliminating incoming Jitter through conversion process from PCM to PWM tiefbassuebertr Digital Source 0 1st February 2012 09:33 AM
PCM to PWM conversion 101 percy Class D 3 30th January 2012 04:08 PM
Tas5261 amp+ analog to pwm controller jash2008 Class D 8 19th April 2011 04:59 PM
dts conversion from analog 4-ch-guy Analog Line Level 0 27th August 2007 08:13 PM
PCM1804 -> TAS5015, Analog PWM amp fr0st Digital Source 0 26th August 2003 12:59 PM
Page generated in 0.06164 seconds (70.25% PHP - 29.75% MySQL) with 10 queries
