Go Back   Home > Forums > Amplifiers > Class D
Old 3rd February 2012, 11:22 AM   #1
JRKO's Avatar
Send a message via AIM to JRKO
Default New amp with dual power
I have been using the hifimediy TK2050 v2 board for some time with a Meanwell 24-27v SMPS 350W power supply and really enjoy the sound. I wanted to up the ante by bringing in battery power.
I know that both power supply setups have been discussed but I want both, in the same box. Switchable mains/battery/charging. Battery for critical listening SMPS for the general duties. The eventual goal is to have my entire system mains free.
I have 2 Yuasa NP7-12 12v 7Ah SLA for a 24v 7Ah power supply and a charger.
My questions are mostly related to wiring up this mess! I would like:
1 switch/knob to choose between battery/OFF/SMPS (switching the mains power not the SMPS output, to save of wasted electricity)
1 switch/knob to turn the mains on/of for the charger
This is going to be a power amp so I need to bypass the pot on the board as well.
Is the battery/Off/SMPS possible?
Also the front panel is american black walnut and I'm torn between a blue LED dc volt meter read out or an analogue gauge gauge to keep tabs on battery supply. What would you choose?
'I have nothing. I owe much. The rest I leave to the poor.
- Francois Rabelais satirist & doctor d.1553
Old 3rd February 2012, 11:29 AM   #2
JRKO's Avatar
Almost forgot. The batteries will need to be wired as 24v for power but 12v for charging
HELP
Old 3rd February 2012, 11:44 AM   #3
acid_k2 is offline acid_k2  Italy
Hi JRKO
why don't you use the power supply also as battery charger?
27V is good for recharge 2 * 12V batteries wired in series.
Old 3rd February 2012, 11:51 AM   #4
JRKO's Avatar
There's no charge protection, float charge mode etc. Just don't want to damage them. Besides, I already have the charger specifically designed for them.
Old 3rd February 2012, 05:27 PM   #5
I think the multi-way multi-position switches you need (or an half dozen of relays and some driving logic), will cost almost more than a new battery set... IMMO some diodes and a current limiter (for batteries charging) will do the job, without the 12V charger. Less complicated wiring, less weight, less things inside the box prone to failure or fire.....
Just my 2 cents.
Old 3rd February 2012, 06:09 PM   #6
JRKO's Avatar
Is there no 3way switch that can handle the SMPS/OFF/BATT?
I've been looking at a mains rates DPDT ON/OFF/ON (not momentary) toggle switch.
Edit: OK after some more reading it cant be done on a single toggle switch.
I can though have SMPS/OFF/CHARGE can't I, as they have a common mains supply!
Please tell me I can do that
Old 3rd February 2012, 08:35 PM   #7
elevator's Avatar
You need a DPDT ON/OFF/ON switch like you say.
Example, 10A Toggle Switches : Toggle Switches : Maplin Electronics
in the version
DPDT-F ON-OFF-ON Double-pole locking, 3-pin, centre off
For the charging, I agree with acid_k2. 27V is just about perfect for charging 24V (nominal) worth of SLA. SLA are made with 2.15V cells in series, 2.15V*12 totals 25.8V. 27V pushes the charging reaction just enough, and is reasonably below the gassing voltage. No need for load balancing, may need a current limiter though.
Here is a good web page on charging SLAs: How to charge sealed lead acid batteries.
You don't need a weatherman to know which way the wind blows --Bob Dylan
Old 3rd February 2012, 11:49 PM   #8
JRKO's Avatar
I've read the link you provided and have learn't quite a bit about charging. Not enough to want to use the smps for charging and not enough to tell my wife I'm not using the expensive charger
As for heat - none of the 3 separate systems will be on at the same time, as charging will be done overnight (I'm on economy7 - cheap electricity between 11pm and 6am. I run my dryer & washer etc at 2/3 normal cost)
I'm thinking more of 3 switches now - less for me to **** up
1 - SMPS on/off
2 - Battery on/off
3 - Charge on/off
the only thing to work out now is the 12v charging/24v powering thingy....
Old 4th February 2012, 12:12 AM   #9
elevator's Avatar
Hey, whatever works for you and your wife
Old 4th February 2012, 12:27 AM   #10
JRKO's Avatar
She holds the purse strings as, for genuine medical reasons, I can't be trusted with money - think $10k+ bipolar lunacy spending...
Dual CV120 amp + Dual CL180 speakers Miguelxj Multi-Way 0 8th December 2011 11:17 PM
New-dual mono power amp # 2 Scorpion Solid State 49 12th May 2008 06:41 PM
New dual-mono power amp Scorpion Solid State 34 13th January 2008 06:31 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
Looking for dual power triodes. Shoog Tubes / Valves 26 21st December 2006 07:19 AM
Page generated in 0.14811 seconds (65.12% PHP - 34.88% MySQL) with 10 queries
