| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
ok so how to wire for 24v power from batteries and 12v charging too them?
This is gonna end up being a bit like the RedWine Audio amps - one of theirs does the 12v/24v thing
'I have nothing. I owe much. The rest I leave to the poor. - Francois Rabelais satirist & doctor d.1553 |
#12 |
I'd gear up a multi-pole rotary switch with a four positions:
- everything off - amp off battery - batteries in series, amplifier connected to battery - amp off AC supply - batteries disconnected, amplifier connected to power supply - charge mode - batteries in parallel and connected to battery charger In the last position, I'd put a low value resistor (1-2 ohms?) in series with each of the batteries. It'll limit a possible current surge between the two batteries if their voltages are different, and it will balance the battery voltages. I haven't thought about how many poles you need in a rotary switch to pull this off. |
#13 | |
that would be one massive rotary switch
| Dual CV120 amp + Dual CL180 speakers | Miguelxj | Multi-Way | 0 | 8th December 2011 11:17 PM |
| New-dual mono power amp # 2 | Scorpion | Solid State | 49 | 12th May 2008 06:41 PM |
| New dual-mono power amp | Scorpion | Solid State | 34 | 13th January 2008 06:31 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| Looking for dual power triodes. | Shoog | Tubes / Valves | 26 | 21st December 2006 07:19 AM |
| Page generated in 0.07217 seconds (73.93% PHP - 26.07% MySQL) with 10 queries |
