| Class D Switching Power Amplifiers and Power D/A conversion |
#121 |
That's a great help. Thanks
![]() Has anyone built this and tested the quality of it?
Another project of mine: (a very big one at that!) http://www.mp3car.com/vbulletin/show...5-pimping.html |
#122 |
How big of a heat sink do these devices need. Do Q3, 4, 5 and 6 need to be sinked? And as for the MOSFETS, if I were to use IRF540 and IRF9540 as suggested earlier in the thread, is there a calculation to work out the heat sink size. I am used to building chip-amps, where there is a nice Excel spreadsheet to help you work out heat sink sizes.
Thanks again for all the advice
#123 |
Sorry to keep asking questions, but her goes....
I understand the principle of Class D amps now, but the output of the comparator will always be a a PWM square wave. It switches N and P MOSFETS when either positive or negative right? If the output of the comparator has to be positive or negative, that means 1 of the MOSFETS (in half bridge) or 2 (full bridge) would be on all the time? If there is no input at the front end of the amp, what is happening at the speaker?
#124 | |
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds. |
#125 |
Oh, I see. So if you PWM was say 200Khz, you have a 200Khz square wave at 50% duty and the low pass filter will not pass this so the speaker sees nothing. So even with no input signal, the MOSFETS are switching 1000s of times a second, but because of the filter, they are not passing any current, therefore not getting warm? Have I got that right?
Oh, just having another look at the circuit. Where is the actual filter?
Another project of mine: (a very big one at that!) http://www.mp3car.com/vbulletin/show...5-pimping.html Last edited by portreathbeach; 13th May 2012 at 10:57 PM. |
#126 | |||
Oh, there's this from earlier in the thread (bolding mone): Quote:
#127 |
Cheers benb. The output part of this amp looks similar to most of the other half wave Class D amps I have seen, apart from the drawing not showing the inductor. The only problem I can see here is the dead time, there is no way of setting it, so you run into a problem of both MOSFETs being on at the same time for a very small amount of time!
benb, have you much experience with Class D amps, and if so, is this a good one to start with, or am I better off building one that uses specific ICs to drive the MOSFETs? If the later option is better, could you point me in the right direction to a simple class D schematic, preferably not using SMT ICs. Thanks again
#128 |
I have no actual experience with Class D for audio, I just know the theory. I've used Class D to drive small motors, which is much less demanding than (good) audio.
I've had good experience doing SMT, and my suggestion is don't be too afraid to try it. Get a good magnifier, a good small-tipped iron, keep everything clean and go for it. Googling for SMT tutorial brings up this: Surface Mount Soldering 101 Video |
#129 |
Hi benb. I'm not too worried about soldering SMTs as I have changed SMT LEDs in mobile phones before, it is more for the reason that standard ICs are a lot easier to use in breadboard prototyping. Thanks for the help, I'll keep looking around for a nice Class D to attemp
#130 |
IMO Simple/Zen designs seem to always sound the best with class A and AB amps weither they are tube or SS. Does simple class D sound as good or is this more of a test of how simple we can make a class D amp and still have useable sound?
| FETish: ultra-simple transconductance amp | Mr Evil | Solid State | 38 | 13th May 2009 11:07 AM |
| The "Freebird" ultra clean ultra simple preamp design | Russ White | Chip Amps | 87 | 11th August 2008 09:28 AM |
| ultra simple distortion effect | apunker | Instruments and Amps | 14 | 22nd February 2005 06:04 PM |
