Ultra Simple Class D
Old 1st July 2013, 07:59 AM   #361
PetruV is offline PetruV  Romania
Shouldnt matter.i had 100mv on one and it barely bothered me
Just a kid who likes building and modding things.No inspirational quote here for you
Old 3rd August 2013, 12:04 PM   #362
stewin is offline stewin  Kenya
Originally Posted by theAnonymous1 View Post
Here is a simple web tool if all you need to know is the turns required for a specified inductance....
Toroid Winding Calculator ? 66pacific.com
do you have a link for ee cores inductor calculator
Old 4th August 2013, 05:58 PM   #363
tom42107 is offline tom42107  United States
Well, I think I really screwed up my amp. I finally finished building the simple class D amp, from etching to populating with all the parts, winding my own inductor, (T106-2). All I had was a simple + and - power supply with two 6800uF caps, one on each rail, and a VH248 bridge rectifier, which is a 6 amp, 200 volt rectifier. My transformer was a 17-0-17 toroid transformer, so I figured aprox. +- 23vdc. So, I hooked it up, turned it on, and the bridge rectifier blew within seconds. I turned it off right away. It didn't look like anything happened to the amp, no smoke or heat or anything. I tested the power supply beforehand and it worked fine. I guess I need to build a really decent power supply and not mess around with quicky built supplies. So, what did I possible screw up on the amp? You can yell at me if you want.
Old 5th August 2013, 05:57 AM   #364
hi please use a 100wt bulb in series with ac to power supply when powering any first project
Old 5th August 2013, 10:08 AM   #365
Hlaford is offline Hlaford  Croatia
Slowing down filling of electrolytes is usually beneficial. Go with the bulb next time.
Old 19th August 2013, 10:33 AM   #366
Originally Posted by jlester87 View Post
Here's my compact layout based on original schem by ejtagle.
Is it tested ?????
Old 19th August 2013, 12:18 PM   #367
JLesterP is offline JLesterP  Philippines
Originally Posted by PetruV View Post
Is it tested ?????
ERC and DRC tested in EAGLE. As long as the schematic is correct, the board will surely work.
You have to do manual electrical testing if you etch your own board.
amplifier PCBs and modules
Old 20th August 2013, 06:07 PM   #368
then im starting tommorow,can this run at +- 20v?
Old 4th November 2013, 07:18 AM   #369
xeclipse is offline xeclipse  Kenya
Location: Where the world's best tea come from:Kericho Kenya
I have Stewin's boards and this is the noise coming out of the speakers with the input grounded. What could be the problem?
Regards.
if there are no sparks,it probably doesn't work!
Old 5th November 2013, 01:40 PM   #370
Regards.
It could be a bad opamp,grounding connection,source,or most probably emi
Ultra Simple Class DHide this!Advertise here!
FETish: ultra-simple transconductance amp Mr Evil Solid State 38 13th May 2009 11:07 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
ultra simple distortion effect apunker Instruments and Amps 14 22nd February 2005 06:04 PM
